PROJECT LO-LYF
Last night I tried to bleed my all new brake system. The master cylinder,lines,pads,shoes,calipers are all new. Here is the question, Do you have to bleed the master cylinder somehow? I put brake fluid in and pumped the brakes about 1000 times but the fluid never went into the lines. I tried opening up a couple bleeder valves but the fluid would still not come thru the line?? Does the truck have to be running to get vaccuum to the booster??
Thanks for any help you may be able to give. Justin ![]()
FOUNDING MEMBER OF THE "O-SH*T, THAT TRUCK IS LOW" CLUB PROJECT: LO-LYF Bagged 68 Shorty home.att.net/~justin.lewis |
You can bleed the master cylinder at the lines on it. I always bench bleed it by pumping it by hand before I install it. You might want to place a rag around the area to help keep from getting fluid all over your engine compartment.
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air. 68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles 68 anniversary no engine long wheel base 400 auto FOR SALE 68 Chevy fleet side long wheel base complete parts truck. |
PROJECT LO-LYF
So how do you go about bleeding the m/c? Do I need to disconect the lines?
Try the directions that came with the mc. I did that once and it worked!hehe
Seriously, I bet your new mc came with a couple of plastic fittings and two pieces of hose. If not you can buy them or make them out of your old brake lines. Disconect the lines at the mc and put these in. Stick the ends in the res with fluid in it. "SLOWLY" work the brake pedal untill there are no bubbles comming out. Can send pics if you need.
The more I learn about women, the more I love my truck. |
BLEEDING BRAKES?
Justin, the best way to bleed the master cyl. is to bench bleed it. i had the same problem when putting mine on. at first i didnt get good flow. but after putting it on the vice and bench bleeding it after 100 pumps or so it started really flowing hard and consistent. at first it was real soft and slow but it got better after this . i thought my master cyl. was bad, but it wasnt the problem though. hope this info. helps . good luck, DAN
1969 cst swb 350/400 th . DANNY C . ["]FRIENDS DONT LET FRIENDS DRIVE F@RD$!! ![]() ![]() 1969 cst swb corvette hugger orange with 400 hp sbc I started out with nothing and i held on to it ![]() ![]() ![]() ![]() |
PROJECT LO-LYF
Thanks for the helpfull hints! I will try them out tomarrow. As for today, I am couch bound to watch the RAMS A.K.A "GREATEST SHOW ON TURF" kick the snot out of the Broncos.
Rudy Fierros '95 Honda VFR750F Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it! |
PROJECT LO-LYF
![]() ![]() That game was a big time joke! You ever heard of a payoff?ha-ha O well, It is a long season, and we prevail!
Yep, thought for sure Griese was paid off to lose that game in the 3rd quarter!
------------------------------------------------ I say it's only money, my wife says it's only a truck.... '71 C10 Deluxe, factory ac, ps, pb, should be done by 2102 Longmont, CO husker95@hotmail.com |
PROJECT LO-LYF
yea colohusker, he wasn't too hot in the 3rd but he stepped it up in the 4th!
I grew up in Lakewood, CO. I am still a broncos fan but not when they are playing the RAMS.
