Garage Queen Material
thinking about cutting a coil
alright, well the front of my truck is still to high for my tastes.
i've got 3" djm spindles and 1.5" western chassis coils up there. there is about 1 1 1/4" gap between my tires and the fender well. i figure if i cut 1 full coil off the springs it would bring it down just about perfect. i'm running doetsch tech shocks on it with 255/50/17" tires would cutting 1 coil out affect the handle enough for me to not want to do it? |
BAD BOW-Silverado XST
Re: thinking about cutting a coil
Why don't you add adjustable air shocks for the rear? My brother did that with his 94. The air shocks allowed adjustment for heavy weight and bed use. Weak leafs can be a problem too.
Dark Heart Motorsports
suggestion? ummm...just buy 2.5" coils bro...then you dont have to worry about a massive reprocussion...coils are built to be what you buy them for, cutting them is not recommended...I'll leave it at that...
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
people have been cutting coils for years.it was once the only way,there were no lowering kits.does it affect ride?in my opinion yes,a little bit.not enough to overide the cool factor for me.that's just me.that being said.i agree a manufactured lowering coil is a better way to go but, cutting is free."free is a very good price" .
" Never look up a dead dogs butt." ![]() |
Cruzzzn' Vet
Boatpuller what size rim and tire package are you running
Flat Black, & Chrome!
I believe they are 17's
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
If you don't cut off more than a full coil it won't effect it that much. Cutting off enough to get more than about 1.5" of drop, will.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#8 | |
225/55/17 in front....275/55/17 in rear, there american racing hopsters.
i think that 1 inch is the difference in our tire height.
That Guy
just 2" or 3" drop coils i got mine for $75 at summit!
Happy to be here
![]() Join Date: Mar 2000
Eric I think you know I am not opposed to cutting coils. I know that you are anal about your truck, so I would suggest you get a 2" coil and sell your 1.5".
I think one coil might give you more than you want, then you have a cut up spring and still need to make an adjustment.
#13 |
i had cheap drop coils (shAIM, but i didn't buy them!!!) and one set an inch lower than the other. i cut the other one to match, taking out 1/4 coil at a time and putting it back to see how much it got me, just to be safe. ended up cutting one full coil. the ride wasn't unbearable, i actually thought it was pretty smooth. the only problem was that i would bottom out hard on my inner fenders with any bump...i don't think i had more than 2" between the tire and inner fender though...
#14 |
Cruzzzn' Vet
1 cut coil will give you a 2" drop, cut 2 coils off to get my 4" drop
![]() 15x9 rim and 275/R50-15 TA's |
#15 |
You should only cut a 1/2 a coil at a time on drop springs because they are allready lower......ask me how I know?
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
#16 |
lol @ airmale...I bet I have a REAALLLLY good idea why you know this!
#17 | |
i dont know if i should get 2" or 3" springs ![]() i dont understand why mine is still as high as it is in the front ![]() |
#18 |
so how much with cutting one coil off of a stock spring give you? surely not 2"
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
#19 |
Until Seventy Times Seven
Here's a chop shot from your current setup (1 1/2" drop coil) to a 3" drop Coil to a 3" drop coil/1" spacer in the rear:
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
#20 |
Mad Scientist
Stock coils cut one coil off is about 2" depending on condition. Lowering coils should only be cut a 1/4 or half at a time. They drop quick! Buy yourself another set and sell those...
![]() 86 1/2ton on tons! sbc/465/208/D60/14/35's 81 Postal....with 468 bbc 97 Merc Marq comuter 07 Suburban 02 Danger Ranger |
#21 |
Bag It!!
