Old 04-17-2007, 11:27 AM   #1
bryanw1968
bryanw1968's Avatar
Converting from manual to power brakes....
I ditched the drum brakes on the front and went to disc a coupla years ago.
However, it's still manual. What do I need besides the vacuum reservoir to make it happen? Will the reservoir bolt right onto the fire wall where the master cylinder was? Any tips would be appreciated.
Thanks,
B
bryanw1968 is offline   Reply With Quote
Old 04-17-2007, 11:34 AM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Converting from manual to power brakes....
You will need the push rod for the power booster as well, they are different between manual and power. Be sure to get a disc/drum prop valve too. You can rebend the brake lines that run down along the frame or use donor lines. And yes, the booster will bolt right up to the firewall. The master cylinder uses the 2 lower studs, and the booster will use all 4 studs.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-17-2007, 12:08 PM   #3
Zonaman
Zonaman's Avatar
Hugh? I thought that manual disc brakes were effective only on the smallest vehciles. How was that thing stopping without a booster- or am I misinformed on this?
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 04-17-2007, 12:20 PM   #4
Blue71LWB
Blue71LWB's Avatar
I've got a '71 with factory front disc and manual brakes. I don't tailgate!!
Blue71LWB is offline   Reply With Quote
Old 04-17-2007, 01:06 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Power brakes were an option. I drive my 72 truck 100 miles per day with manual brakes. It stops fine.
Old 04-17-2007, 01:10 PM   #6
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Yep my 71 had manual disks and i put on power. It stopped fine.
LOW DOUGH is offline   Reply With Quote
Old 04-17-2007, 01:49 PM   #7
bryanw1968
bryanw1968's Avatar
Oh it stops great, but you gotta earn it.
Old 04-17-2007, 02:17 PM   #8
krue
Designated A-hole!
krue's Avatar
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 04-17-2007, 03:55 PM   #9
bryanw1968
bryanw1968's Avatar
I just talked to a vendor that I usually buy stuff through and he said that a lot more parts. I think it might be time for a junk yard run?
So I need the following:
A new master cylinder as he said mine won't work even though it was made for a disc brake vette.
A proportioning valve.
Bracket for the proportioning valve.
New lines.
New rod.
Brake booster.
There has to be a cheaper/easier way to do this with out spending $400???
I thought once I had actually gotten the rotors on that would be the only expensive part?
Any advice always appreciated.
B
Old 04-17-2007, 04:09 PM   #10
krue
Designated A-hole!
krue's Avatar
New lines? You shouldn't need new lines, you shouldn't really need a new m/c iirc.
www.daveramsey.com
Old 04-17-2007, 04:23 PM   #11
53burb
53burb's Avatar
sometimes you do need a new M/C...it depends on the bore length of the M/C....shallow or deep...power boosters usually require the M/C to have a shallow bore....
53burb is offline   Reply With Quote
Old 04-17-2007, 04:58 PM   #12
Yeller68
Active Member
Yeller68's Avatar
That's funny!
Yeller68 is offline   Reply With Quote
Old 04-20-2007, 02:14 PM   #13
OLDIRON69
Are the lines, for instance on a '69 with drum on the front. Will those lines work when doing the swap? Just add a prop. valve and the other necessary bolt on,steering components etc. I was told I need "disc brake lines" like on a '71-72. I know I need the flex lines that go to the calipers. I robbed the brackets for the brake lines off the '71. I guess what I'm asking is will the hard lines be the same/work??
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 04-23-2007, 04:57 PM   #14
Zonaman
Zonaman's Avatar
I used a new booster, master cylinder, & proportioning valve. The original lines from my drum brake setup were kept. Needed adapters to fit them into new prop. valve, that was it. Of course I had to change out the ball joints to accept the '73 types.
Old 04-23-2007, 05:23 PM   #15
krue
Designated A-hole!
krue's Avatar
I used adaptors and bought new hoses, but now I'm junking all of that and going with the booster/master cylinder/ prop valves/ lines from an 83. To connect the 72 calipers to the 83 lines I have to use the hoses off a 73 (before they went Metric on the banjo bolt on the calipers).
www.daveramsey.com
Old 04-24-2007, 08:25 AM   #16
OLDIRON69
Talking Re: Converting from manual to power brakes....
What are you gonna do with the adaptors and new hoses?? If your sellin'? I'm intrested.
05 2500HD 6.0 excab
Old 04-24-2007, 11:36 AM   #17
69_hafton
Sleep-Deprived
69_hafton's Avatar
I'm adding a vacuum booster to mine right now. Thing I'm trying to find out is if there's a different grommet/boot for the firewall. The manual master cylinder had a boot, but with the master cylinder now in front of the booster, there needs to be a boot or a grommet for the pedal rod to travel through?
The vacuum booster has these brackets to attach it to the firewall. You need a different push rod from the brake pedal to the center of the booster linkage pictured:
1971 K/10 Long Fleetside
350/350 - 6" Lift
1969 C/10 SWB 292 - Sold It
69_hafton is offline   Reply With Quote
