Old 04-17-2007, 12:22 PM   #1
my 85 gmc
Question Lowering question?
Would it be possible to lower the rear suspension on a 85 GMC Sierra Classic 2.5-3 inches using 2 inch drop shackles and removing a spring leaf? If so which spring leaf would you remove The truck has 5 leafs now. Thks Rob
my 85 gmc is offline   Reply With Quote
Old 04-18-2007, 11:06 AM   #2
bwright
Re: Lowering question?
Yes, it would be possible, but I'd get a flip kit instead (easier to install & easier to go lower later).
1977 Chevrolet C10 - 305/TH350, SWB, Stepside, 3/5 drop...work in progress.
bwright is offline   Reply With Quote
Old 04-18-2007, 12:02 PM   #3
FlatBrokeRacing
FlatBrokeRacing's Avatar
Would it be a must to remove a leaf or are the shackles enough.
FlatBrokeRacing is offline   Reply With Quote
Old 04-18-2007, 01:51 PM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
How would he go about getting the 2.5-3" of drop with a flip kit? That would give him at least 5 inches of drop, wouldn't it?
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-18-2007, 10:21 PM   #5
benoit454
Chris
benoit454's Avatar
I keep seeing ppl saying "flip kit" and I think they just mean a shackle or flipped upside down hangers from the front lol, you know the lowering hangers.
I'm not sure though, I was thinking the exact same though, a flip kit drops it like 6 inches and requires c notch for clearance.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 04-19-2007, 12:17 AM   #6
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
I'm thinking a 2" drop shackle will only give you a 1" effective drop without using a drop hanger. To add another 3/4" drop or so the overload leaf spring (bottom-most leaf) can be removed.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 04-19-2007, 12:22 AM   #7
boxrodz
boxrodz's Avatar
Slonaker
Slon, one guess is to replace the stock hanger with a 4x4 hanger, since they are taller. I'm not certain as to what the final drop would be.
boxRODz
Old 04-19-2007, 12:57 AM   #8
my 85 gmc
The reason I'am wanting 2.5-3 inches of drop in the rear is because i would like to buy 2.5 inch dropped spindles so I can run my 8 inch rally wheels(which have new GM centers, trim rings and tires) till I decide which wheels I want. But my other problem is wanted to buy Western Chassis spindles but can't find someone who will ship them to Eastern Canada. Early Classic Enterprises lists 2.5 inch spindles for 73-87 chevy trucks and so does GMC Paul's(not sure what brand) does anyone have input on these products? Thks Rob
Old 04-19-2007, 06:48 AM   #9
bigblock73
yeller
bigblock73's Avatar
Sport Truck Direct sells Western Chassis spindles, and I am sure they would ship to Canada. Try them.
bigblock73 is offline   Reply With Quote
Old 04-19-2007, 09:11 AM   #10
Slonaker
Slonaker's Avatar
But that's not a flip kit...
Slonaker
Stock '01 Silverado
Old 04-19-2007, 09:17 AM   #11
Slonaker
Slonaker's Avatar
I bought my WC spindles from http://www.performancesuspension.com/. No problems with them or the WC parts. I don't know if they ship to Canada.
I think someone sells a set of shackles/hangers that has a couple of adjustment holes to choose from. That would allow you to choose 3" or 4" of drop for the rear. I can't remember which manufacturer has the adjustable setup, but I bet someone here knows.
Slonaker
Stock '01 Silverado
Old 04-19-2007, 09:48 AM   #12
boxrodz
boxrodz's Avatar
Slonaker
My guess was to imply that a flip kit could be used to get a 5"-6" drop, then use a 4x4 hanger to raise the drop back up a couple of inches or so to lessen the overall drop.
boxRODz
