Old 04-17-2007, 04:16 PM   #1
JkC824
ready to burn my truck
Here is the problem, I am not getting any fuel from any of my tanks. I changed the fuel tank selector valve, relay, filiter, elec. pumps, selector switch in cab, relay on fire wall and put a new computer in it. The pumps will run if i run a hot wire to them but i still don't get fuel at the carb/fuel injectors. when i checked to see how many V i get at each tank its only .63 and that is the same at the switch in the cab. What could be the problem? Please someone help me!!! Thanks
JkC824 is offline   Reply With Quote
Old 04-17-2007, 06:37 PM   #2
benoit454
Chris
benoit454's Avatar
Re: ready to burn my truck
I had sort of a simialr problem on my camaro, you need to track down the wiring for the pumps and make sure it's all good.
What happened on me was the wire came from the battery to a distribution block on the radiator craddle, well the hot wire's terminal broke off and so it only got volts when it wanted to or if it got moved in the right spot.
I changed pump, filter, relay, plugs, all kinds of crap, and still nothing, then find the broke wire. I was pissed.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 04-17-2007, 10:03 PM   #3
BaddBusa2005
BaddBusa2005's Avatar
dont do it, ill come pic it up this weekend
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
Old 04-17-2007, 10:16 PM   #4
Pyrotechnic
Pyrotechnic's Avatar
Don't burn it! I could put it to good use. It's been 6 months since someone plowed into mine and totalled it and I still don't have a 73-87 or any transportation for that matter. I've been walking.
Not sure what the problem is but the best advice I can offer is to go over it with a multimeter.
Pyrotechnic is offline   Reply With Quote
Old 04-17-2007, 10:56 PM   #5
bmartin9122
bmartin9122's Avatar
Sounds like a partial short to me. In other words, a wire has some insulation rubbed off or is pinched, and a lot of current is running to ground directly (but not enough to pop a fuse).
79 GMC Sierra Grande K15
--PPG paint code 62608 Sunburst Orange Metallic (WA802K)
--Gentex auto-dimming rearview mirror model K31
--Carriage Works billet grille model 40071
--Go Industries 2.5" tubular stainless headache rack
--Sylvania Silverstar sealed headlights model H6024ST
--Texas Saddlebags center console model 101
--Brown's Welding class IV V-5 pipe bumper
--Ramsey RE8000 winch
--33" tires
bmartin9122 is offline   Reply With Quote
Old 04-17-2007, 11:51 PM   #6
liljon285
That Guy
liljon285's Avatar
I got dibs on the engine!
1978 Chevy Scottdale Stepside, 3rd engine- 350c.i. built with cam and lifters, holley 670cfm carb. and intake,heads shaved .60. Truck is a project, and I am its restorererer!
liljon285 is offline   Reply With Quote
