Old 04-25-2002, 09:17 PM   #1
70jimmy4x4
Post Tach no worky ! How to test Tach
Found the tach wires, hooked-up as I was told to...it doesn't work. How can I determine if it is the TACH and not the wires?
I have elec. ign. dist.
Steve
'70 jimmy 4x4
'98 chevy zr2 (the misses' transpo)
'65 stang
'81 shovelhead
contact me: email--showme219@aol.com
'70 jimmy 4x4
'65 stang
'81 shovelhead
'99 Dodge Ram 1500
70jimmy4x4 is offline   Reply With Quote
Old 04-25-2002, 09:26 PM   #2
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
Red wire goes to ignition power and brown goes to the distributor( back plug in on HEI)
72 Chevy C/10
87 Chevy Silverado 4X4
www.geocities.com/chevylwb/chevylwb.html
Aberdeen South Dakota
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 04-25-2002, 09:31 PM   #3
jmanz69
Careful, they attack...
jmanz69's Avatar
Post
If you have a multimeter, you can use the Ammeter to check it. Just set your meter up for checking current, and then connect across the tach. The needle should jump if it is working. this will just let you know the tach is not bad.
jmanz69 is offline   Reply With Quote
Old 04-25-2002, 10:00 PM   #4
70jimmy4x4
Post
Jman,
I assume that test is run with eveything connected correct ?
'70 jimmy 4x4
'65 stang
'81 shovelhead
'99 Dodge Ram 1500
Old 04-26-2002, 11:46 PM   #5
jmanz69
jmanz69's Avatar
Post
NO, don't leave it connected!! disconnect the tach and have it separate. you could backfeed and blow something. Just to be on the safe side. Good Luck.
Old 04-27-2002, 05:20 PM   #6
70jimmy4x4
Post
OK, will NOT test it while it is hooked-up !
'70 jimmy 4x4
'65 stang
'81 shovelhead
'99 Dodge Ram 1500
Old 04-27-2002, 07:19 PM   #7
Desert Rat
Desert Rat's Avatar
Post
Touch the metal back to a ground source,while hooked up.
Desert Rat is offline   Reply With Quote
