04-17-2007, 06:32 PM | #1 |
diesel conversion
Could anybody tell me what is involved with putting a cummins in a 69 1/2 ton longbed. I would really appritiate any help you guys can give. Thanks in advance.
04-17-2007, 06:43 PM | #2 |
Son of a gun
Re: diesel conversion
Well, a lot of fabrication and problem solving, but it could and has been done. Have you searched the here for cummins cnversion yet? If not that is where I would look first. After that google the web and see what you find.
Now a 6.2 conversion could be a relatively easy swap but you would not have the "bling" of a Cummins convert. I have been kicking this idea around especially since you can pick a good one up for MUCH cheaper than a Cummins, but with the price of diesel these days, you would have to drive a bunch to make up the cost.
Bill BEATERS ARE NEATER |
04-17-2007, 07:49 PM | #3 |
Watch out for your cornhole !
A 6bt Cummins weighs 1100 pounds, so suspension will certainly need to be addressed.
A 4bt would be the best choice. It's basicaly a 4 cylinder version of the Cummins used in Dodge pickups.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 04-17-2007 at 07:50 PM. |
04-17-2007, 07:56 PM | #4 |
I agree............A tweaked 4BT would be the ticket for your truck.
I got a 6AT in my 3/4 ton............It is a tad lighter than a 6BT at 950 lbs, but it definitely squats the stock 3/4 ton front end with HD springs. IMO, their isn't nothing better than a Cummins in one of these. Mine will be going under the knife again to finally ready it for paint, and then I can drive it and look good, right now it looks like crap, but does she run!
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
04-17-2007, 08:01 PM | #5 |
Thanks for the help. I am a little diesel illiterate so bear with me. What kind of power can i expect and what were these motors in. Thanks again you guys are great.
04-17-2007, 08:14 PM | #6 |
Don't even worry about horsepower. It's the torque that makes them great. I have a 6bt in my Dodge truck that's right at 1000 ft/lb of torque. Nothing like it. I have real basic mods like injectors, pump and turbo tweaks.
04-17-2007, 08:28 PM | #7 |
what were these motors in. Thanks again.
04-17-2007, 09:12 PM | #8 |
89 and newer dodge 3/4 and tons
Jared
1969 GMC 910 1970 GMC 1500 custom 1972 yamaha 175 "Money is just like trucks you can never have enough" |
04-17-2007, 09:30 PM | #9 |
what about the 4bt. What were thay in. thanks
04-17-2007, 09:34 PM | #10 |
GM step vans like FritoLay and Mrs. Bairds delivery trucks. This is the way to go as they already are coupled to a Turbo 400 trans.
04-17-2007, 09:39 PM | #11 |
Are these also a turbo or a strait diesel. Thanks again for all your help. Its nice to have such knowlegable people to bounce ideas off of.
04-17-2007, 10:20 PM | #12 |
Bite me, import boy
Yes, they are turbo.
Jason
Jason '71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project "Facts are meaningless, You can use facts to prove anything that's even remotely true." |
04-17-2007, 11:05 PM | #13 |
Recovering Truck Driver
I'm thinkin' Duramax!!
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
04-18-2007, 08:42 AM | #14 |
ROTFLMAO, That is a pretty good joke
A 4BT can be turned up a pretty good amount before things start to fail. Know alot of guys running them in log skidders and other equipment turned way up. About the only bad part about the 4BT IMO is they are pretty noisy and vibrate a bunch. One of the reasons I went with the 6AT, even though it really isn't any better of a engine than the 4BT, its just silky smooth when it runs.
04-18-2007, 10:17 AM | #15 |
I`m thinking I could pump alot of gasoline through a big block with what a Dmax conversion would cost.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 04-18-2007 at 11:30 AM. |
04-18-2007, 11:14 AM | #16 | |
Bite me, import boy
Jason
Jason '71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project "Facts are meaningless, You can use facts to prove anything that's even remotely true." Last edited by HugrOrang71; 04-18-2007 at 11:17 AM. |
04-18-2007, 12:13 PM | #17 |
Put some stacks on it if you do the conversion!
http://www.parleysdieselperformance....69/page/845090 Check out the video Last edited by Ole Blue 68; 04-18-2007 at 12:15 PM. |
04-18-2007, 12:29 PM | #18 |
Active Member
i will have a used duramax soon not sure what to do with it though i have my eye on a 69 panel 2wd i think would be cool
04-18-2007, 12:53 PM | #19 | |
Dano
'69 Fleet It ain't yours, if you didn't build it! |
04-18-2007, 12:55 PM | #20 |
04-18-2007, 04:18 PM | #21 |
I really appritiate all of your help. My only concern about the 4bt is will the th400 hold up after turning it up. Thanks again for all your help.
04-19-2007, 02:11 PM | #22 |
Honestly, I've been told by more than a few that a TH-400 won't hold up behind a stock one, let alone one turned up. I have a GM clutch and bell housing adapter in mine, and she's tore up everything from the flywheel back atleast once. I plan on bolting in a HD ZF-6spd, which has a oil pump/cooler setup when I tear it down again.
04-19-2007, 04:35 PM | #23 |
Thanks TP, I was actually thinking of useing a 5 or 6 sped from a Dodge. I just need to see how hard it will be to do. I would love to see some pics of your ride to see what I am in for. Thanks again for all your help.
04-19-2007, 06:10 PM | #24 |
Hey you would need to still be careful if you put in a 5 spd. They aren't built very strong either.but they can be made strong. I have been told the 6 spds are more up to the challenge. The key here would be to get a good clutch.
04-19-2007, 11:27 PM | #25 |
As far as suspension goes...Does an`89-up Dodge 2wd really have a beefier suspension than these trucks?
