04-17-2007, 07:52 PM | #1 |
OK, needing some help with truck measurements...
OK, I'm going to try and start a new way to determine the amount a truck in lowered... but, I need help getting the initial measurements...
What is the measurement from the top edge of a fleetside bedside to the wheel arch opening? What is the measurement from the bottom edge of the cab rocker (that lip on the bottom) to the top (peak) of the cab? More questions to follow....
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
04-17-2007, 08:15 PM | #2 |
Dave's not here, man
Re: OK, needing some help with truck measurements...
I got 14" for the bed measurement and 55 1/4" for the cab measurement.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
04-17-2007, 08:29 PM | #3 |
Ok, So...
this may be a tough one... what is the measurement from the centerline of the rear axle to the bottom of the rear axle housing pumpkin... = difference of ground to center of rim less (-) bottom of pumkin to ground? ALSO,... is the bottom edge of the fenders in front of tire and behind tire, parallel? OK, wait... what does your truck measure just in front of rear wheel (bottom edge of bed), then at the bottom of cab, right at the front edge of door, then just behind front tire (bottom edge of fender) and then bottom edge of fender just in front of front tire
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 04-17-2007 at 08:36 PM. |
04-17-2007, 08:34 PM | #4 |
Would it be the same as measuring the heighth of the pumpkin and halfing it?
04-17-2007, 08:37 PM | #5 |
probably,... not positive...hmmmm...
also I added to above post...
04-17-2007, 08:52 PM | #6 |
Top of the pumpkin from the ground: 18 3/4"
Ground to bottom of pumpkin: 8 1/8" That makes the pumpkin 10 5/8" tall Centerline would be 5 5/16" Still working on the rest.
04-17-2007, 09:01 PM | #7 |
The bed is actually off the truck so I don't think I can get those measurements, if I'm reading the post right anyways. For the door measurement, do you mean on the hinge side of the door or the latch side? I'm going to get the front fender measurements now.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 04-17-2007 at 09:04 PM. |
04-17-2007, 09:03 PM | #8 |
Well, if no bed... I would need both... but not bottom of door, bottom of CAB, below door...front (hinge side) and back (latch side)...
really just checking here to see if truck is level or raked, etc...
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 04-17-2007 at 09:05 PM. |
04-17-2007, 09:08 PM | #9 |
Also, just verifying....
is your rear tire approx. 27-1/2 or 27-3/4 inch tall? Centerline of center cap of rim is approx, 13-3/4 inches from floor...?
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 04-17-2007 at 09:38 PM. |
04-17-2007, 09:37 PM | #10 |
Front of fender: 11"
Rear of fender: 10 1/4" Front of door: 9 3/4" Back of door: 11 1/4" Tire heighth: front: 26 3/4" rear: 28"
04-17-2007, 09:46 PM | #11 |
perfect...
I'll get back to you.... I need to compute all this info with the info I already had.... Thank you
04-17-2007, 09:50 PM | #12 |
Glad I could help!
04-17-2007, 09:51 PM | #13 |
Ooops,...
Sorry... the point exactly where the front fender meets the rocker.... that measurement from the ground to the bottom of rocker/fender point is what?
04-17-2007, 10:06 PM | #14 |
10 1/4"
04-18-2007, 12:20 AM | #15 |
Thanks...
