Old 04-17-2007, 09:52 PM   #1
Dadsredwagon
Dadsredwagon's Avatar
starting issue
replpaced solinoid two times , here is my issue 65 230 motor. turn the key click like starter wants to engage, nothing , if you try again you get dim ligts on oil and gen light but no click or anything.... open the hood disconnect positive battery cable, reattached sometimes this works, but mostly I have to jump the solinoid using a screw driver between the battery cable post on the solinoid and the right termimal on the solinoid, again this only works sometimes. so any idea's ??
thx..
Dadsredwagon is offline   Reply With Quote
Old 04-17-2007, 10:00 PM   #2
desertrat
desertrat's Avatar
Re: starting issue
oh boy! Electrical problems drive me crazy.
Things to check
-battery fully charged?
- bettery terminals clean?
- battery cables tight on post and at starter?
-are cables old? ( I have seen what looks like a good cable but somewhere in the wire it was corroded, but you couldn't see it )
- is there alot of oil on the starter? , making a poor ground to the block. ( I never seen this as a problem but heard about it)
The list goes on keep us updated maybe we can help.
desertrat is offline   Reply With Quote
Old 04-17-2007, 10:47 PM   #3
bowtieguy61
Re: starting issue
the one things that bites a lot of people, ground! make sure the battery has a good connection to the frame. and also a good ground strap from the motor to the frame. ive been bit by the ground bug way too many times.
bowtieguy61 is offline   Reply With Quote
Old 04-18-2007, 12:44 AM   #4
slepysal
slepysal's Avatar
Re: starting issue
yea make sure the starter is clean as well as were it mounts. Also (I'm sure you did) have you tested the starter it self? A bad bendix will do it.
slepysal is offline   Reply With Quote
Old 04-19-2007, 02:01 PM   #5
mateo1279
mateo1279's Avatar
Re: starting issue
I agree with bowtieguy61! My electrical probs always seem to be ground issues, usually a cleaning/conection issue. I have gotten in the habit of checking that first now...
Matt
1962 Chevy Fleetside
283/TH350
mateo1279 is offline   Reply With Quote
Old 04-19-2007, 03:42 PM   #6
62 short step
62 short step's Avatar
Re: starting issue
Matt
62 short step is offline   Reply With Quote
Old 04-22-2007, 12:10 AM   #7
Dadsredwagon
Re: starting issue
thanks all!!! it was the ground..... whew..
