Can anyone offer a second openion as to what this i.d number checks too? I have tried to decode it, but it decodes as a 72, 3/4 ton, 400 cid ,210 hp, 8 1/2-1, 4bbl. The problem with that is that I'm positive it is a 350 block.
Thanks. |
Active Member
Re: Engine Decoding
you didn't include the block id #
"The Great State of Florida" |
Re: Engine Decoding
Sorry all it's VIO22KW.
![]() Join Date: Sep 2000
Re: Engine Decoding
I don't find any with a KW
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
Active Member
Re: Engine Decoding
Where are you finding this #, VIO22KW, as it's not a standard engine casting #...
GEARHEAD
Re: Engine Decoding
Yea I've got nothing listed like that. Get the block casting number of the back. I have seen racers stamp what ever on the front pad just to make it look good when going through tech. Ya may have some thing odd though.
72 SWB 2WD MY PROJECT 72 LWB 4X4 FUTURE PROJECT SUBSCRIBE HEREBOARD VENDORS HERE NORWOOD MEET SURVIVOR! ![]() Last edited by RACINJASON22; 04-17-2007 at 11:36 PM. |
Re: Engine Decoding
goin through tech is fun aint it
but just get the numbers off of the back of the block on the lefthand side behind the valvecover
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Re: Engine Decoding
This casting came off the front of the block, front of where the head bolts to the block. I think it was passenger side. All of my other numbers that I have ran checked correct. I have seen a casting number before on the back of a block that was 0010. It was down close to where the transmission bolts up. Is this the same location that I need to check on this block? I have found a 72 engine code that is KW, but it says it a 400. I'm sure this block is a 350. Here is the link I found..http://www.americanclassic.com/paint.htm?p1=engines.
I'll take another look at this block and let you all know what the one on the back is. Thanks for all the input. I have found a lot of good information here. |
Re: Engine Decoding
I think that is for a Big Block.
