Old 04-18-2007, 01:11 AM   #1
ElkyRacer
Scored some McGaughys drop spindles/springs, now what?
I just scored a set of drop spindles/springs from a 67-71(not sure on the year, saw the truck but never asked for sure) truck for a bill! 2.5 and 2in springs. Now Im rounding up everything else Ill need to install. I got the part # for the balljoints/tre as he even had his old boxes from the install. Im going to have to go with disc brakes for the spindles tho. Who would you guys suggest getting a kit from? Who uses stock components so I wont have to order expensive pads/rotors/calipers when time for replacing? When dropping the rear 5in or so is an adjustable track bar needed? Who has the least expensive rear springs/notch? Or should I just make my own c-notch? Anything else Im missing? Now to find some stock steelies and make some white walls!!
Thanks.
Kyle
ElkyRacer is offline   Reply With Quote
Old 04-18-2007, 02:08 AM   #2
stepside66
stepside66's Avatar
Re: Scored some McGaughys drop spindles/springs, now what?
I am going with autozone rotors and calipers just so if anything breaks lifetime warranty and making a rear notch isnt hard especially if you do a mini notch
stepside66 is offline   Reply With Quote
