Old 04-18-2007, 02:05 PM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
Breathing in exhaust fumes
When I open the windows I'm bringing in exhaust fumes from the space between the bottom of the hatch and top of the tailgate. I have a tailgate trim piece I bought awhile back but in looking at it today, it's holes aren't in the right place and it isn't actually wide enough.
Anyone done anything creative to seal this location?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-18-2007, 04:13 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Breathing in exhaust fumes
Take the damn top off
J/K, No idea so ttt 4 ya
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-18-2007, 05:16 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
A PO put some adhesive back weatherstip on the tailgate hatch stop, It looks kind of like the stuff you can get at the hardware/home improvement store.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-19-2007, 02:03 AM   #4
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
There's that peel and stick 1/2" foam tape you can get just about anywhere.Try that 1st,should work.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 04-19-2007, 06:49 AM   #5
vtblazer
vtblazer's Avatar
Is your exhaust going straight out the back or the side?
If their straight out the back, almost nothing you try will be 100%.
Putting the tail pipes out the side is the only way I've ever found to cure it.
vtblazer is offline   Reply With Quote
Old 04-19-2007, 11:09 AM   #6
jhow66
jhow66's Avatar
Try one of those spoilers that defect the airflow that comes across the top down the back to keep window clear.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-19-2007, 12:10 PM   #7
Yukon Jack
Post Whore
Yukon Jack's Avatar
The exhaust presently does exit behind the K5 but in a few weeks I will be doing the exhuast and it will be side exit.
I hear you on taking the top off! That is on the agenda once it gets a little warmer around here.
I threw a little masking tape on the hatch to the tailgate last night cause I just hate breathing the exhaust smell - looks nice and ghetto but it will work until I make something to cover that area.
Old 04-19-2007, 12:33 PM   #8
OLDCHEV4X4
OLDCHEV4X4's Avatar
I put the exaust out the side too...just for that reason.
I also had to stuff a long pc of foam between the bottom of the tail gate and the floor.
In the summer time i tryed driving around with the hatch up to get some air in for the people in the back. Can't do that. The fumes come right in.
So i mounted a fan back there for them.
The draw backs of a blazer.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-18-2007, 09:33 PM   #9
TonyJohnson
TonyJohnson's Avatar
Hey folks, I'm resurrecting this thread because I did a search on weatherstripping for the tail gate and didn't find much. Today I installed part 38-6963, end gate lower seal, from LMC and used part 38-0792, loctite black weatherstrip adhesive and man did it make a difference. My exhaust exits at the rear corners like the pic vtblazer put up and because of the gap between my tailgate and bed, my '71 Blazer always smelled like exhaust. Today after everything dried I went for a test drive and WOW... Should have done this a long time ago...
Tomorrow I'm going to tackle the upper window weatherstripping on my Blazer top. It's pretty bad and has been leaking, so I'm going to give it a try.
Later,
Tony.
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 08-20-2007, 09:53 PM   #10
RED72blazer
urban fourwheelin
RED72blazer's Avatar
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 08-21-2007, 10:50 AM   #11
Yukon Jack
Post Whore
Yukon Jack's Avatar
I took Luv's advice and yanked the top in May and that put an end to my exhaust smelling days.
Course winter is on it's way but I happened to pick up something slight used a couple months ago that I think it will solve my hard top exhaust problem.
Don't want to brag or anything but do the letters S T C mean anything?
Old 08-21-2007, 08:44 PM   #12
RED72blazer
urban fourwheelin
S T C....Nice!
Old 08-22-2007, 09:45 AM   #13
jhow66
jhow66's Avatar
No????
Old 08-22-2007, 09:48 AM   #14
Yukon Jack
Post Whore
Yukon Jack's Avatar
Originally Posted by jhow66 View Post
No????
Huh?
Old 08-22-2007, 02:06 PM   #15
jhow66
jhow66's Avatar
Forgot to quote "STC mean anything to you". In other words what does it mean?
Old 08-22-2007, 02:59 PM   #16
Yukon Jack
Post Whore
Yukon Jack's Avatar
Ah, now I get it. S T C means Specialty Top Company and I was trying to not brag that I lucked out a while back when boardmember LivRat I believe it was posted up a craigslist add he had seen for a hardly used STC Fastrack soft top. I bought it for $300 and so now I probably won't be using my hard top any more.
Old 08-22-2007, 06:30 PM   #17
jhow66
jhow66's Avatar
Good buy!!
Old 08-26-2007, 09:20 AM   #18
Mike C
Mike C's Avatar
Congrats on the top! Like VT says, if the exhaust exits out the rear you'll have problems. Turn it out the side. Besides, any self respecting off-roader would never run the exhaust out the rear. If you get stuck and have to rock the truck back and forth you can pack the exhaust full of mud, water, or both!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
