Old 04-18-2007, 07:34 PM   #1
jlaird
jlaird's Avatar
What did I screw up??
I was welding on my lower control arm today. Before I started, the crossshaft turned freely. After I finished welding, I froze it up. I can barely turn it with a pair of pipe plyers. I thought maybe it temporarily expanded by the heat, but after it cooled down, I still cant move it. What happened? Should I replace the whole shaft or can I just replace the bushings?
josh
jlaird is offline   Reply With Quote
Old 04-18-2007, 08:22 PM   #2
pissonNOS
senior member
pissonNOS's Avatar
Re: What did I screw up??
is it possible the bushings just got too hot and have melted around the shaft? just a guess?
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 04-18-2007, 08:26 PM   #3
jlaird
jlaird's Avatar
I don't know, maybe. From the outside they look normal.
Old 04-18-2007, 10:37 PM   #4
pissonNOS
senior member
pissonNOS's Avatar
probly wouldnt hurt to change them anyways
69 GMC bagged
Old 04-18-2007, 11:29 PM   #5
SCOTI
SCOTI's Avatar
How much heat did you generate? What/where were you welding?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-19-2007, 01:22 AM   #6
jlaird
jlaird's Avatar
I am making some custom bag mounts. I did a lot of welding on them. I'll post some pics when I'm done in my build thread. They are coming out pretty nice!
Old 04-19-2007, 10:42 AM   #7
SCOTI
SCOTI's Avatar
Sounds like you may have warped the arm vs. what is was before welding. Try putting it in a press if it looks bowed one way or another (might not be able to tell though).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-19-2007, 10:46 AM   #8
jlaird
jlaird's Avatar
Thats what I was afraid of. Oh $hit!
Think I can fix this?
Old 04-19-2007, 06:16 PM   #9
XXL
Seņor Member
XXL's Avatar
I vote the latter. The shape of the a-arm stamping sure looks strong. I can see the old, nasty rubber bushings melting on the inside (where they're pressed up against the overheated metal).
XXL is offline   Reply With Quote
Old 04-19-2007, 09:35 PM   #10
jlaird
jlaird's Avatar
I took the cross shafts out and reassembled them. The bushings didn't melt. I think after I cut the spring pocket out, the arm slightly tweaked because I didn't have enough bracing on it. I put the shaft back in and it seems to be ok. One thing I have learned from welding is you can never use enough bracing. On the other control arm, I braced it in three spots around the shaft area. I'll post some pics tomorrow of my masterpiece!
Old 04-19-2007, 10:25 PM   #11
XXL
Seņor Member
XXL's Avatar
I cut the spring pocket out!
I missed that little detail.
Old 04-19-2007, 10:31 PM   #12
SCOTI
SCOTI's Avatar
....I think after I cut the spring pocket out, the arm slightly tweaked because I didn't have enough bracing on it.
When you mentioned fabricating bag plates.... this was the image I visualized & why I thought the arm was possibly warped.
Try to only weld 1" @ a time & allow the material time to completely cool if you can't brace what needs welding.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-19-2007, 10:43 PM   #13
XXL
Seņor Member
XXL's Avatar
Remember... if the metal gets too hot, you can use the insides of your arms as a heat sink to cool it down. Wait, er... don't do that.
Old 04-19-2007, 11:21 PM   #14
pcmcobra
pcmcobra's Avatar
lol
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 04-20-2007, 02:17 PM   #15
SCOTI
SCOTI's Avatar
Young grasshopper. . ..... If you can take the ......
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
