Old 04-18-2007, 08:37 PM   #1
corkscrew
Where can you find the original specs from a stock 1970 c-10?
just want to look at some numbers, any help would be great
corkscrew is offline   Reply With Quote
Old 04-18-2007, 08:39 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Where can you find the original specs from a stock 1970 c-10?
What type of info are you needing?
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 04-18-2007, 08:41 PM   #3
corkscrew
well the gear ratio, the weight of the Long bed, im basically curious about everything but those 2 are the main
Old 04-18-2007, 09:29 PM   #4
slt0066
i'll try and find the number for you but you can call genral motors customer service and ask for a restoration packet and they will send you one for your truck. It has a lot of info, tire sizes, engine spec, dimensions and such.
takes a week or so to get and its nothing fancy but you cant complain cuz free. and neat to have.
there was a thread on here a few months ago about it
slt0066 is offline   Reply With Quote
Old 04-18-2007, 09:31 PM   #5
corkscrew
does any one off hand know the weight of a long box c-10 and its stock gear ratio?
Old 04-18-2007, 09:39 PM   #6
neonlarry
neonlarry's Avatar
What tranny & engine? 350/350 usually had 3.08's.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 04-18-2007, 09:42 PM   #7
corkscrew
well it had a 350 originally yes....any clue what the weight is?
Old 04-18-2007, 09:45 PM   #8
woodrow59
OzarkHillbilly in Atlanta
Here's stuff about the "repro pack"
http://67-72chevytrucks.com/vboard/a...hp/t-2221.html
72 custom/10 LWB
68 Longhorn C20 Custom Camper (sold)
woodrow59 is offline   Reply With Quote
Old 04-18-2007, 10:05 PM   #9
corkscrew
too bad i am not from the states
Old 04-18-2007, 10:16 PM   #10
cdowns
cdowns's Avatar
you can find all sorts of interesting info in the factory service manuals its about the best $25 you can spend on your truck
Old 04-18-2007, 10:41 PM   #11
corkscrew
so any one who has it would you care to share the info with me.
Old 04-18-2007, 10:48 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you have a 350, but what tranny is it?
Weight is supposed to be something like 3600 pounds I think, but I have yet to witness one on a scale that light, I've seen short wheel base rigs over 4000 pounds.
Old 04-18-2007, 10:50 PM   #13
Ace in the hole
I have the 1970 restoration pack from GM with all the specs, very helpful.
According to what they sent me-
The c10 LWB (models cs10934 and ce10934) have curb weights of 3605 and 3737 lbs respectively.
As for gear ratios, depends on your engine. 3.07, 3.73 and 4.11 were the main ones available and a 3.54 was used for the 400 engine and ch465 4 speed and the new process 435cr 4 speed tranies.
250 and 292 sixes-- std was the 3.73
350 v8-- std was 3.07
307 v8-- std was either a 3.07 or 3.73 depending on your trany
400 v8-- std was 3.07 unless you had one of the tranies mentioned earlier.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 04-19-2007, 12:23 AM   #14
corkscrew
thanks guys for your help it was a 350 with a 3 speed 400 tranny
