Hilp figure out what it's worth.
I'mtrying to decide whether or not to buy this truck to resell parts to help fund my own project.
67 Small window A.C. cab with all A.C. components except compressor. Rust in typical spots, uncut dash. don't know about cab mounts 67 8 lug coil rear, don't know much else about it. 67 power steering gearbox Good driver tailgate w/out any rust through, I'm sure I may find a few small pin holes. used edelbroc 1405 carb 67 front grill in pretty good shape. 4 core radiator top supports. core support in pretty good shape. trailing arms in pretty good shape. inner fenders... no rust. ![]() Thanks a bunch! Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 04-18-2007 at 11:15 PM. |
![]() Join Date: Feb 2004
Re: Hilp figure out what it's worth.
What's not to know, buy it, use what you need and sell all the rest.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
This is what will be left. Wife doesn't want another junk truck. Trying to see what the interest is for real. Don't want to buy it then sit on it for months.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
