Old 04-18-2007, 10:54 PM   #1
MXmaniac
MXmaniac's Avatar
C-20 rearend ID
What rear-ends were available on the 3/4T trucks? I know the DANA 60 was, but was there another one available? I don't think mine is a DANA and I would like to swap in some taller gears, because the PO put in some insanely low gears.
Thanks in advance.
Andrew
'69 C-20(292, 4-speed) Retired Daily Driver
'64 C-10(250, 3-speed) Fixerupper
'97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver
If I only wanted two pedals I'd have bought a bicycle.
MXmaniac is offline   Reply With Quote
Old 04-18-2007, 11:08 PM   #2
JAKES 68GMC
Aluminum slot wheels rule...
Re: C-20 rearend ID
Your truck more than likely has a Eaton HO-52 rear end in it. As far as putting in higher gears, you'd be better off to get a different axle. The Eatons are obsolete, and the highest gears you can get for them are 4.10 ratio.
JAKES 68GMC is offline   Reply With Quote
Old 04-18-2007, 11:22 PM   #3
MXmaniac
MXmaniac's Avatar
Re: C-20 rearend ID
Darn, not what I was hoping to hear. Thanks for the info.
Andrew
Old 04-18-2007, 11:56 PM   #4
72armyswbtruck
72armyswbtruck's Avatar
Re: C-20 rearend ID
Do you have any pics?
I had a post on here that Identified the different rear ends.
Let me find the link.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-18-2007, 11:57 PM   #5
72armyswbtruck
Re: C-20 rearend ID
Here is the link:
http://67-72chevytrucks.com/vboard/s...d.php?t=234234
