Junior Member
How Bad Is This Rust???
I don't know that much about repairing it but doesn't look that bad to me. What do you think? The cab corner is fine accidentally attached.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
Re: How Bad Is This Rust???
Not bad at all. Easy fix. Quit leaning on the door with your arm though. The acid in your body is eating away at the metal. I told you I have your twin.
Son of a gun
That is just surface rust. I'd hit it with a DA sander and epoxy primer. Any pits that may be left use a little filler primer. No problems there, very fixable stuff.
Bill BEATERS ARE NEATER |
Here is a pic of what can be done to the hood. This spot was done in less than 1 minute I believe is what I timed it at. The longest part was letting the rust killer soak in.
just replace the cowl with another...they are usually cheap <$20. Door looks like it's the worst...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Junior Member
That amazing. I've been worrying about that rust for 10 years. You sure made meel fell better. Someone here always seems to have the answer. Is that true about the acid from your arm?? Wish I was half as wise. Thanks
Yes, that is why they rust like that. That is why you should never touch bare metal with your bare hands either. It will come back and haunt you after you paint the vehicle. Sometimes you will see a paint job and you can see someone's fingerprint or palm print lifting the paint. That is where someone touched the bare metal and did not clean the surface properly.
Junior Member
is the blue and white the one that now has the red front? just wondering because if i was going to change that would have been my choice
Yes, that is the truck in my avatar but the red fenders were for my 72 2wd Blazer that I have. I am going to go with a 67 front end now so those fenders will be for sale soon!!
GEARHEAD
I agree you should be
HOLY MOLY! What do you all do with that stuff? Is someone eating your trucks at night in the dark or what!! Nice 200mph tape on that lt bedside though.
Junior Member
I get your point that sh*ts killer. I recently moved to east tx from Dallas and you should see all these truck out here they are everywhere mostly longbeds
for farms, ranchs etc. good place to look for trucks. saw a good one go last monthy for 2k would have been easy $3500 in Dallas area. I'll pass deals along now that i'm hooked up.
#13 |
GEARHEAD
Well I don't know what ate mine I bought it this way. Knowing that everything was going to be replaced from the frame up. Luckily the frame is pretty nice. I wanted a frame up project anyway. I did drive it home after I bought it Central OH to Central PA.
72 SWB 2WD MY PROJECT 72 LWB 4X4 FUTURE PROJECT SUBSCRIBE HEREBOARD VENDORS HERE NORWOOD MEET SURVIVOR! ![]() Last edited by RACINJASON22; 04-19-2007 at 12:43 AM. |
#14 |
That is hilarious RacinJason. Glad you have a good attitude. That is funny, but you are right about frame up!!
#15 |
RacinJason, Thats not so bad! You need to use that foil furnace tape and shoot it with a can of red primer. It look as good as new .
I wish I has a pic of the truck I looked a few years ago, The guy made cab supports out of 2x4's and fixed the floor with plywood. Then to top it all off, he stuffed rags in the rust holes in the cab corners and bed and topped it off with what else......cement! ![]()
68 GMC 64 1/2 Mustang convert A bachelor's life is no life for a single man." - Samuel Goldwyn |
#16 | |
GEARHEAD
#17 |
Junior Member
racinjason you got a couple 72's know anything about getting 72 towers and mounts for bb
#18 |
Make sure you use that Permatex rust treatment after sanding rust away.That will come back and haunt you,if you don`t.
I think it`s oils and salt from your skin that soften and rust the doors.Maybe a combination of both.But,it`s oil from your fingers on bare metal that needs to be cleaned before painting.
#19 |
heres some rust for ya and yes i am fixing it anything is posible
1972 c-20 chevy 500 caddy/4.10posi / 1972 3/4 ton gmc 350 4x4/4.10posi front&rear ![]() ![]() ![]() |
#20 |
couple more
#21 |
This will make you feel better about your "rust" issues... This was a NY born and raised truck... Luckily he undercoated it and it saved a majority of the frame and body. My 97 Camry has more rust than your truck, it was a NY car too....
#22 |
As you have seen, there are a lot of people fighting rust. The choice is whether you want to take on the time and cost of fixing it. I had a cab that required a lot of work, although not as bad as some of the others I have seen. Before I started to repair the cab, I found an A/C cab on Craigslist for $500 (including the frame). I couldn't pass up the deal or the extra parts and picked it up a day after paying for it. You can see the pic of my floor board and sort of see what I started with, but undertstand, this picture does not give justice to what a "cancer" basket I really had.
70 C-10 350/700R4, 2.5/4 drop to be completed by 12/07 |
#23 |
What's up with the mouse traps? Is that what ate your floor!?
#24 |
Forum jumper here...
You should have no problems getting that rust taken care of. Check out my project thread for a little inspiration. http://67-72chevytrucks.com/vboard/s...d.php?t=210104
My 51 project http://www.cardomain.com/ride/2285825 My 68 Camaro project http://www.cardomain.com/ride/2277404/1 |
#25 |
Junior Member
Thanks for all the input. I wasn't sure if this was really just surface rust.
As was pointed out guess I am pretty lucky and shouldn't be a fourtune to fix. Felling alot better ![]()
