04-18-2007, 11:36 PM | #1 |
Aluminum slot wheels rule...
Another speaker question
I want to put a stereo in my GMC. I have the CD player, a nice Pioneer one, now I just need some speakers. I'm not going to cut the doors apart to put them in. I don't want to do kick panels, either. I'd like to put them under the seat, or under/inside the dash maybe? Someplace where they will sound good, regardless. I have no clue what to buy for speakers. I'd like to have the clearest, best sounding speakers there are that don't cost too much. (less than $50 ) So, I guess my two main questions are:
1. where should I put the speakers? 2. what should I buy for speakers to get good sound quality? Thanks for the help, I just need some tunes in the GMC. |
04-18-2007, 11:38 PM | #2 |
Re: Another speaker question
.......The motor should be the tune
04-19-2007, 05:57 AM | #3 |
>130dB Moderator
If you aren't going to cut anything, place the speakers in the dash. It's the best possible place you could put them. It is however, a PITA.
I wouldn't count on anything larger than a 4" speaker fitting inside that small space. Unfortunately, there isn't much out there for the tiny sum of money that you are talking about... Look into some either some Eclipse or Pioneer coaxial speakers. Whatever you do, don't put speakers underneath the seat... They sound like crap and don't put out hardly any volume.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
04-19-2007, 09:02 AM | #4 |
I dragged what was left of what looked like a 6x9 under the dash a while back, it was up under the dash, next to my steering column.
Tiny sum of money?! $50 is a LOT of money, especially for some speakers! |
04-19-2007, 10:59 PM | #5 |
>130dB Moderator
lol
Maybe I'm just out of touch with the low-budget speaker installations. (My "cheap" speakers are $400 retail...) The speakrer you're talking about was closer to the center of the dash IIRC. I think it was a 4x6? Correct me if I'm wrong. LMC truck makes some replacement speakers for the dash that will fit your budget and should bolt in place without any modifications to the dash or metal. I can't speak for the quality because I've never heard them...
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. Last edited by AceX; 04-19-2007 at 11:00 PM. |
04-20-2007, 01:46 PM | #6 |
You can buy a pair of 3.5" speakers that will work in the dash. What I do when we install these is take out the original speaker, if still there, use it as a template to cut out 1/4" MDF. Mount the speakers under the MDF so the cut out will fit flush.
I have a great sounding no-name 3.5" in my truck. They cost $30.00/pair at any car stereo place. Make sure not to get dual cone. get the 3.5" with a tweeter. You will be a lot happier. Good Luck on your quest. |
04-20-2007, 09:15 PM | #7 |
AceX, the speaker was further away from the center of the dash, it was under that gauge panel. It didn't look like factory stock, but it had been crammed in there for awhile, 20 years or more.
72 cheyenne, I should get some 3.5" speakers with single cone and a tweeter and put them under the dash? They only cost $30 and sound great? That sounds like a plan. I hate to sound dumb, and I really feel dumb right now, but what is a tweeter??? |
04-20-2007, 10:07 PM | #8 |
That's what I did. Here is a little run down of a speaker. You have 2 parts that reproduce the sound. The tweeter and the woofer. The tweeter usually reproduces the sounds from around 4khz to 20khz. The woofer usually reproduces from the 4khz to about the 20hz range. Now depending on the size of the woofer will determine the lower range in the sound reproduced. A 3.5" woofer will never be able to reproduce the 20hz sound. There just isn't enough cone area to get it that low. A 3.5" speaker will usually go down to about 1khz to about 600hz.
Ideally this is what you will want to get the full sound. Tweeter - 20khz - 4khz Mid-Range - 4khz - 1khz Mid-Bass - 1khz - 80hz subwoofer - 80hz - 20hz Good luck in the system you decide to go with. |
04-20-2007, 10:25 PM | #9 |
Ehhhhh, ok. I guess I get what you're saying. I'll go look in wal-mart nxt time I go and see what they have for speakers.
04-21-2007, 01:47 PM | #10 | |
Chevys Kick A$$
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
04-21-2007, 08:21 PM | #11 |
I looked under my dash today to try and imagine where to put the speakers, shouldn't be too much trouble. Lots of room under there. Thanks for the help guys, I think I will go with a Pioneer speakers to match the CD player. My dad had a Pioneer 8-track in his Camaro back in the 70's and loved it. He swears by Pioneer stereos.
