04-19-2007, 07:49 AM | #2 |
Re: Any reason not to...
Wussat?
04-19-2007, 08:07 AM | #3 |
Licensed to Thrill!
Yea, RE who?
DLB |
04-19-2007, 10:37 AM | #5 |
Licensed to Thrill!
That was my first thought...but hey, thanks for enlightening the rest of us.
DLB |
04-19-2007, 10:59 AM | #6 |
67 is sold
04-19-2007, 11:20 AM | #7 |
In my opinon the RE6 are a little light for your truck I would not run any thing lower than an RE7
04-19-2007, 02:03 PM | #8 |
Run the RE7. You need the weight and the added lift is nice too. They both lower the same.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
04-19-2007, 03:57 PM | #9 |
Correct me if I'm wrong, but isn't there only a difference of 100 lbs. between the RE-6 and the RE-7 as far as weight capacity goes? If you're using a stock shock setup up front, you won't be able to use the extra lift capacity of the RE-7, at least I can't. I have RE-6s up front and my shock tops out before the bag reaches max height. The cool thing about the RE-6 is that it's smaller in diameter (obviously), and I didn't have to use cups. I just made a flat circular plate that sits in the lower coil pocket, no clearance issues what so ever.
04-19-2007, 06:12 PM | #10 |
Seņor Member
What's the basis of your question? As in... why are you asking? Got some RE-6's cheap? or???
04-19-2007, 10:58 PM | #11 | ||
Texas Big Wig
Diameter: 6" Min height: 3" Max height: 10" Max PSI: 180 RE-7 Diameter: 7" Min height: 3" Max height: 11" Max PSI: 180 RE-8 Diameter: 7.75" Min height: 3" Max height: 11" Max PSI: 180 RE-6 Replaces a firestone 255c or contitech 2500# bag. (Front) RE-7 Replaces a firestone 224c or contitech 2600# bag. (Rear) RE-8 Replaces a firestone 2800# bag. (Rear duallys) Yeah, only 100 lbs & one inch smaller tall & wide Quote:
I just thought that if I could do like thekid54 And not use cups & just make a flat circular plate that sits in the lower coil pocket, that It'd solve part of the "nose bleed" problem (front sitting higher than rear) Thanks Joe67, you |
04-19-2007, 11:18 PM | #12 | |
Texas Big Wig
If anyone has pics of the upper being reverse cupped, that'd be great too I just wanna get as low as I can, without spending much money & I can't afford lower arms or drop spindles (plus I see no reason I can't get as low as I want, by just running no cup on the bottom & if I have to cup the top) |
04-20-2007, 03:12 AM | #13 |
Epoxy Primer Friendly
CHECK THESE OUT
04-20-2007, 08:35 AM | #14 |
Thats what I am in the middle of doing! Slightly different though.
04-20-2007, 12:37 PM | #15 |
my arms use to be like that but i decided to drag them off. now i have stock arms with 1 inch cups.. i ran the re-7s and then switched to the 6.. i ended up having to run more pressure to get less height.. it says its an inch shorter but i think it was alittle more in my case.. either way i still have plenty if height to get over stuff
04-20-2007, 10:14 PM | #16 |
Texas Big Wig
I'm love'n those Do you think that they'd hold water ? |
