Motor mounts and headers
I have a 1965 C10 fleetside with short box. I am going to replace the in-line six with a 350. So I need help finding motor mounts and headers. Thanks for any help.
Randy65 |
Newbie truck Rebuilder!
Re: Motor mounts and headers
For Motor mounts , try CPP, they carry motor mounts...
http://www.classicperform.com/6092chevtrk.htm Also try the local board vendors..... You can also use the old style V8 mounts...... As far as headers go, they will have to clear the motor mounts, and it depends if you run an auto or a manual tranny as to what will fit.....
"Old Blue" 1964 GMC Fleetside in pieces 350 TPI with 700R4 tranny now installed( well kinda propped in place until the tranny crossmember is bolted in ![]() 1995 Toyota 4runner , 197,000 miles and going... ![]() 2007 Honda Odyssey Van (Wifes car) ![]() ![]() |
Thanks, and I will be running an automatic.
I'm not sure how much variation there is out there, but I yanked a 230L6 from a 64 C10 and put in a 350 from a 71 GMC camper special in. The 350 bolted right up to same motor mounts, same bell housing (3-speed). Attachement for clutch linkage was in right place. I was amazed how simple it was to do the swap.
I'm told the 230 and 250 have same mounts as sbc 350, but 292 passenger side mount is different, further forward than the others. You would only need to replace the mount on this side to do the swap. I also used the same headers (tube headers, not oem cast iron) from the 71 GMC. I had to move a lever on the clutch linkage, I think the piece is called a bell-crank. Had to move one of the arms closer to the block. Other than that, the headers cleared the frame, motor mounts, etc. I don't know the origin of the headers. |
