Old 04-19-2007, 12:09 PM   #1
HuggerCST
HuggerCST's Avatar
72 dropped spindles compared to 73-87
Can anyone tell me the differences? I have a set of 73-87s on the way, and want to put them on my '70. I figure since I have to change the ball joints & tie rods anyway, I'll just use 73-87 stuff, but was just curious what the differences are. The spindles are for 1" rotors.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 04-19-2007, 01:38 PM   #2
HuggerCST
HuggerCST's Avatar
Re: 72 dropped spindles compared to 73-87
I called the local NAPA and according to their computer, the bottom ball joints, calipers, and rotors are the same from 72 to 73, but there is a difference in the tie rods end and upper ball joints, whatever that may be.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 04-19-2007, 06:18 PM   #3
XXL
Señor Member
XXL's Avatar
The 73+ tie rod shafts are a larger diameter, IIRC. So if you go with them, you'll need inner, outer, and adjusting sleeve. I seem to recall someone making a custom sleeve that allowed you to mix 72 inners and 73+ outers... but it was more expensive than just replacing inners and outers.
XXL is offline   Reply With Quote
Old 04-19-2007, 09:47 PM   #4
HuggerCST
HuggerCST's Avatar
Ok, thanks. Since mine is a '70 with drum brakes, I've got to change all the tie rods either way to go with discs, so I'll just go with 73-87 stuff. I assume that I'll have to use the 73-87 centerlink, but not sure. What about the 1" or 1&1/4" rotors? Is that a year model thing, or an optional thing?
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 04-21-2007, 12:46 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
The 1" rotors didn't appear until around 1980. Unless you got a sweet deal on them, get your spindles "HD", These are the 1 1/4" rotor spindles. I went to the 1" rotor on my pickup when I dropped it and can definitely tell the difference in braking from the 1 1/4". I deal with it 'cause they were basically free. The 1" and 1 1/4" rotors are NOT interchangable. I would go ahead and grab a 73-87 center link too, but then you may run into pitman arm compatibility issues. You gonna lower it some???
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-22-2007, 11:59 AM   #6
HuggerCST
HuggerCST's Avatar
Yea, I'll probably wait until later when I can afford some wheels, but the spindles were a deal, so I bought them. Thanks for the info, that explains alot.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 04-22-2007, 03:53 PM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
I've got a really nice set of 5-lug rallies over here that came off my Blazer if you're interested.
-Chris
