Tire opinions: White Letter or all Black?
So what do you all think? Which should I go w/? I have all black right now, but thinking of going w/ white lettered ones. Of course, pics are always good.
1969 C/10 swb, 350, powerglide (daily driver) 2005 CRV (wife's ride) |
Questionable
Re: Tire opinions: White Letter or all Black?
Depends on the wheel. If you're sticking with those wheels, they're pretty plain, I would say lettered....
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
68 C10 Longbed
![]() Join Date: Sep 2006
I have factory rallys and the white letter look great.
![]() Join Date: Nov 2004
Depends on rim/tire and truck.
I like rally's with white letters out. They're dirty, but you get the idea.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 04-19-2007 at 04:12 PM. |
Black wall out with rallys..........or any other wheel for that matter.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
Any time I have had white lettered tires, they were facing IN. I think they look best that way, no matter what wheel or vehicle I have had them on. JMHO
![]() Join Date: Oct 2005
Though I prefer blackwalls, I think white letters work with rallys just fine and look best with a popular name brand tire....BFG, Goodyear, etc....
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Well, I like both looks. Will be staying w/ ralleys for awhile, so I'm thinking heavily about going from the black 235/75/15s to the BFG TA Radial white letter 275/60/15s.
i like the black out and the white out equally, but if you have the black out now why not go white out on the new ones and change it up a bit
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
heres some pictures
I think you're right, GMonkey. Think that size would be the right one, and how would it affect the speedo?
i dont know the stock tire size but my tires are 31's according to the side wall theyre actually like 29-30in but my speedo reads 5mph under, as in if my speedo says 50 im actually doing 55mph, 235's might read over
#13 |
my speedo w/ 235s is fast, but if I figured it right the 275/60s are a little shorter but wider. Just not knowledgable about how the tires affect the readout. do both width and height factor? I would think that height would affect the speedo the most.
#14 |
only height will change the speedo, the width of the tire affects your traction and mpg to believe it or not
275 will be taller than 235, which IIRR the stock tires were 275 or 285, something like that
#15 |
I was reading on tire tech that the 235 and 275 is actually width from outer wall to outer wall in mm. Then the height (from rim to outer edge) is a percentage of the width (e.g. 235/75 , height is 75% of 235mm)... That is IF I read the article right.
so..235/75 = 235mm/25.4 mm/in = 9.25" wide and 9.25in x .75 =6.94" tall .....275/60 = 275mm/25.4 mm/in = 10.83" wide and 10.83in x .6 =6.5" tall Again, this is probably wrong...
#16 |
So as the tire gets wider, the mpg gets smaller?
#17 |
the tire sizes confuse me with that but i just found a calculator and according to it the 275/60/15 is actually smaller than the 235/75/15, so i would say go with a 275/65/15 and youll have a 29in tire which might read right but im not 100% sure
#18 |
yes, more tire touching means more drag means less mpg
#19 |
oh heres the calculator i found, im sure theres better but its the first one i clicked on and it works
http://www.miata.net/garage/tirecalc.html the black ring is the colum on the left and the black wall is the colum on the right
#20 |
Personally i think it depends on the tire.
Some tires have UGLY lettering.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
#21 |
very true
#22 |
The Original HotRod KnifeMaker
![]() Join Date: Jan 2007
I think you should...............
....................................... do whatever looks best to YOU. It's your truck, make it yours ![]()
Dave 69 GMC SWB 2WD 454 Turbo 400 |
#23 | |
tirerack,.com has an explanation that's actually easy to follow...
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 04-20-2007 at 04:42 AM. |
#24 |
The LuvShack Garage
I personally like Black out on low pro's, white out's on 4wd's
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#25 |
I always turn white in.I like attention to go elsewhere.I forgot to tell the tire guy to mount the letters in on my`92 GMCwork truck which is totally stock and it sets it off.I`d never turn any letters out unless they were a good name tire.It`s all preference,but as a rule I`d say two-tones and trimmed out trucks look best with blackwalls and letters are ok on solid paint plain Janes.
