Old 04-19-2007, 04:09 PM   #1
ktlx1
Question Power Steering Help
All, my power steering gearbox began leaking, then a whining noise, then no power steering. Getting ready to put a new gearbox in, what is the procedure to bleed the gearbox.
ktlx1 is offline   Reply With Quote
Old 04-19-2007, 04:23 PM   #2
Orence1
Orence1's Avatar
Re: Power Steering Help
My first attempt was lock to lock with a full pump and the motor running. Fluid kept frothing up. Called tech at Redhead. He suggested lock to lock with out the motor running. Check level, refill, repeat process until no drop in fluid level. Solved the problem and its working great. I forgot to mention that it is much easier if you elevate the front end so that the wheels are off the ground. Good luck.
Orence1 is offline   Reply With Quote
Old 04-19-2007, 04:24 PM   #3
shifty
Questionable
shifty's Avatar
Man, now if I could just figure out how to do this with no steering column....
I suppose I could jack up the front end and move the wheel back and forth.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-20-2007, 12:56 AM   #4
72lb4x4
With power steering, you can slip the rag joint couple on, and with the motor running, PS pump turning, etc., turn it by hand.
I put a new pump, lines, and box on my 72 4x4 recently, and bled it in about 15 seconds. Turn one direction til resistance, turn the other way til resistance, repeat until lock to lock. It took no time at all.
Then I topped off the resivour, resivuor--er... spinny thing the fluid goes in.
72lb4x4 is offline   Reply With Quote
Old 04-20-2007, 01:55 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
when we were rebuilding the P/30 step vans at work, we found turning lock to lock with the engine off was the best way to do it. Then once you think it's good, fire it up and crank it lock to lock a couple times and check the level.
Old 04-20-2007, 03:27 AM   #6
GREASEMONKEY72
GREASEMONKEY72's Avatar
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
