Old 04-19-2007, 05:51 PM   #1
djw32
5 lug conversion question
Hello,
I searched the FAQ's, but I could not find the information
Where should I go for the rear 5 lug conversion? I need the axles and drum brakes. Also, I need to get the front setup as well...who do you guys recommend for this?
What five lug wheel can I run for a short while? For example: s-10, 88-98 1500?
Thanks, David
djw32 is offline   Reply With Quote
Old 04-19-2007, 05:57 PM   #2
BarryB
BarryB's Avatar
Re: 5 lug conversion question
71, 5 lug rear will bolt right in. That is what mine had done before I got it. If you don't want to change out the rear diff. Check around your local machine shops. Take the your axles and drums and have them drilled for the 5 on 5 lug pattern. The 6 lug axle flanges have enough metal to compensate for the extra holes.
As for wheels, Somebody posted a list of what cars and trucks use this bolt pattern. so check around the forums you might find it.
I do know, a S10 wheel won't fit they are 5 on 4 3/4.
BarryB is offline   Reply With Quote
Old 04-19-2007, 06:02 PM   #3
krue
Designated A-hole!
krue's Avatar
The older S-10 wheels won't fit. The newer S-10 wheels are 5 on 5 I believe (I know they are bigger than the 5 on 4 3/4)
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 04-19-2007, 06:19 PM   #4
djw32
my bad...
I have a 1970 c-10 swb
Old 05-18-2007, 11:11 PM   #5
onelow69c10
what all 5lug axles will fit into the factory 69 rear end will an 73-87 work?
onelow69c10 is offline   Reply With Quote
Old 05-18-2007, 11:17 PM   #6
1969k10stepside
None will stock....the axle isnt as wide as the 70+ rear axles.They could be made to work,its just not a slide in,bolt down and go process,though
1969k10stepside is offline   Reply With Quote
Old 05-18-2007, 11:28 PM   #7
onelow69c10
one guy said the 73-79 will bolt right in and anything older will be 3/4in longer but will work is this false?
Old 05-20-2007, 03:28 AM   #8
onelow69c10
any info on this woud be great help as I am doing this one way or another this week
