Old 04-19-2007, 07:38 PM   #1
woodrow59
OzarkHillbilly in Atlanta
alternator housing ??
My '72 alt. has the bracket on the bottom (long bolt) that bolts on to the back of the alt.. The new alt I got last week didn't match where I needed to bolt the bracket. It was off by 1/4 turn. I took out the 4 bolts holding the front and the back of the housing together and carefully turned the housing to where it needed to be.
Would or could this have messed up something inside the alt ???
72 custom/10 LWB
68 Longhorn C20 Custom Camper (sold)
woodrow59 is offline   Reply With Quote
Old 04-19-2007, 08:20 PM   #2
JimKshortstep4x4
Re: alternator housing ??
As long as you turned the winding with the rear part of the housing and did not separate the two halves to where the brush came off of the end of the armature, you should be ok.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-19-2007, 08:33 PM   #3
woodrow59
It would charge after I put it on, But I suddenly had a key off drain. Finally figured out today that the alternator was causing the key off drain. Would anything I did make it do this ??
72 custom/10 LWB
Old 04-19-2007, 08:41 PM   #4
truckdude239
truckdude239's Avatar
yes if you accidentally damaged the diodes
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-19-2007, 08:52 PM   #5
woodrow59
I know rebuilt alternators and starters are often bad,,,,,, so I don't know if I messed it up or not.
Well, I guess this is more of a moral question,,,,,,, should I take it back ??
72 custom/10 LWB
Old 04-19-2007, 08:58 PM   #6
KAILUAZ
King of Rust
KAILUAZ's Avatar
If you pulled the housing out too far you might have popped that small spring out, or the small metal piece may have fallen out also.. I did this one an alt when changing the "clock" position. I had to take it to a alt shop and have them put it back together.
Good luck!
1970 GMC 2500, 350, TH400, front disks, thats it!
My Pics
KAILUAZ is offline   Reply With Quote
Old 04-19-2007, 08:59 PM   #7
rage'nrat638
rage'nrat638's Avatar
most good auto parts stores can test it. for free
rage'nrat638 is offline   Reply With Quote
