Old 04-19-2007, 09:15 PM   #1
69snb396
Alternator wiring harness - Revisited
This morning I was led to toddtheodd's harness modification post through krue's FAQs after I posted a question as titled above. Todd's post was apparently very thorough, however I did encounter a problem this evening when I did the modification to my harness and now have another question. For those who haven't looked at the post, it was originally posted 09-12-2004 at 07:55 AM and is listed among krue's FAQs. My question is: What becomes of the red wire cut from the external regulator plug?? It is not mentioned in the re-wire procedure. After checking for (and finding) continuity between this red wire and the red wire to be connected to the alternator I assumed that the wire was no longer required and cut and capped it and enclosed it in the old harness re-tape. I'd like to get confirmation that this was the right thing to do before I complete the connections and try it out. I'd especially like to hear from toddtheodd and welcome any input from anyone who can help. Thanks.
69snb396 is offline   Reply With Quote
Old 04-19-2007, 09:40 PM   #2
Madbomber88
Active Member
Madbomber88's Avatar
Re: Alternator wiring harness - Revisited
I just ran out to my truck to check this and when I did this I didn't cut that red wire at all, just kept it attached to the plug. When you are all said and done, the red and white wires are left in the plug and the plug just dangles wherever.
Hope this helps.
I followed that same thread and had no problems and am very happy I did it, made a huge difference.
71 Blazer CST
72 K20
Capt USAF
Madbomber88 is offline   Reply With Quote
Old 04-19-2007, 09:51 PM   #3
69snb396
Thanks bomber. So from what you've said, abandoned in the plug or abandoned (capped) inside the harness tape is the same. It's probably OK but since it wasn't mentioned I thought "better safe than sorry". Thanks again.
Old 04-19-2007, 09:56 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
You can eliminate this red wire or use it to connect the alternator to the battery via the 4 way link in the original harness as pictured in the website below. Ignore the horn relay as trucks don't wire it in this way. The diagram is for cars but it's basically the same in trucks.
http://www.madelectrical.com/electri...evymain1.shtml
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-19-2007, 09:59 PM   #5
rage'nrat638
rage'nrat638's Avatar
Thumbs up Re: Alternator wiring harness - Revisited
welcome to the board
your really going to love your new alt..
rage'nrat638 is offline   Reply With Quote
Old 04-19-2007, 10:12 PM   #6
69snb396
Thanks vette.
Old 04-19-2007, 10:13 PM   #7
69snb396
Thanks rat.
Old 04-20-2007, 12:17 AM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Originally Posted by 69snb396 View Post
Thanks vette.
you're welcome and welcome to the boards.
VetteVet
