Bench testing the factory AM radio
I pulled a factory AM radio out of a 70 GMC parts truck and I would like to install it in my 69 GMC.
Before I install it I would like to test it to see if it works. Can I simply run a 12 volt supply to the radio and ground the case? Does the speaker need to be grounded as well?
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
>130dB Moderator
Re: Bench testing the factory AM radio
In short, yes. You need to run 12v power and matching ground to the radio.
The speaker does not have to be grounded unless otherwise specified by the manufacturer.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
Hummmm, makes me curious of the long answer!
Thanks for the help, it works!
