04-19-2007, 11:55 PM | #1 |
power steering mounting help. pleasssssseeee!
hey all i cant remeber show the power steering pump mounts to the block could someone with a stock or close to stock setup post pics. thanks in advance.
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness! my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal: I'M SO SO CAL! |
04-20-2007, 12:27 AM | #2 |
Re: power steering mounting help. pleasssssseeee!
The photos below are not the greatest - it was dark under the hood and a trouble light was not near at hand.
In the first photo you can see a bracket bolted to the block (bolts numbered with a 3). Bolt 2 attaches the A/C compressor to this bracket, and bolt 1 attaches the p/s pump bracket to the first bracket. The second photo is more from the top (sorry about the dirty engine). The bolt indicated attaches the p/s pump bracket to the block. Hope this helps... |
04-20-2007, 11:00 AM | #3 |
350+dual flows= fun :)
i wonder if all 73-87 trucks have crooked P/S pumps, ive never had a truck where the P/S pump pully lines up perfectly with the other pullys
ALWAYS CHECK YOURE FRONT WHEEL BEARINGS!! SPINNING OUT ON THE FREEWAY DUE TO THE BEARING GOING OUT IS PRETTY HAIRY!!! |
04-20-2007, 03:54 PM | #4 |
Robert Olson Transport
come to think of it mine is off too i tried to shim it but it never worked out ok
04-20-2007, 10:08 PM | #5 |
The Crazy Machanic
my pulleys are straight for the power steering but the belt of the fan is not needs some washers. Also my brackets are from a 63 impala.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) * 1970 chevelle 2dr sedan Latest update June 24 2007. *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one |
04-21-2007, 10:37 PM | #6 |
Thank You Thats Exactly What I Needed
