04-20-2007, 08:28 AM | #1 |
Will 15 x 10 rallys fit on the front also?
I may have an oppurtunity to buy some vette style rallys in red (what I want) but They are all 15 x 10. Waiting for the backspacing. Will 15 x 10 even fit the front? They were on a 90 suburban. I have a 68 with 73-87 front crossmember with disc brakes. Here are the rims:
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
04-20-2007, 08:48 AM | #2 |
Re: Will 15 x 10 rallys fit on the front also?
I am running 15X10 all around with 295 50 15's fit's great!!!!!!!!
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" |
04-20-2007, 08:52 AM | #3 |
SWEEEEEEEEEEEEEEEEEEEET!!!! Do you have a pic?
04-20-2007, 09:34 AM | #4 |
Here is A couple old pictures
04-20-2007, 09:42 AM | #5 |
Thanks for the pics!
04-20-2007, 10:02 AM | #6 |
is that stock suspension on you 70 with 295/50/15
04-20-2007, 10:14 AM | #7 |
where is best place to get ralley wheels 15x10 for my 71 swb with 5x5 bolt pattern
04-20-2007, 11:32 AM | #8 |
this is the setup i am currently usings on the rear and in the front 15x8, 265-60-15' s
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
04-20-2007, 02:54 PM | #9 |
its all about the +6 inches
my old SWB had 15 X 10's all around, and never had a problem. (Couldn't tell you the back spacing though) The original 500,000 mile old front springs sagged enough to call it a 2 inch drop too.
04-20-2007, 03:03 PM | #10 |
Yeah they'll fit... I have 15x10's all the way around with 275R60/15's on all four corners. I have a 2 1/2" / 4" drop as well. They fit and look good!
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
04-20-2007, 03:16 PM | #11 |
I have 15x10's all around. Front tires are 255 60 15 and the rears are 275 60 15's.
04-20-2007, 03:36 PM | #12 |
Will it look goofy with 285 70 r15 3 1/2 inch wide white wall tires? I am concerned the white walls will look goofy on a rim that wide.
Shawn
04-20-2007, 05:40 PM | #13 |
285/70 is quite a bit taller (about 3" taller and 1/2" wider) then the above mentioned ones (275/60). It should still work with stock suspension, not sure about any drop though. 10" (well 9.5 actually) is the widest rim recommended for both tires, so I think the white-walls should be OK. the height is the only thing I can think of as an issue, but again I think it will work since I had 31/10.50x15s on my truck for a while
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 04-20-2007 at 05:46 PM. |
04-20-2007, 05:42 PM | #14 |
i have 15x10 all the way around
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-20-2007, 07:14 PM | #15 |
Any body know if front=245/60r15----rear=275/60r15 tires would fit on a 15x10 rim and what they would look like.And how they will fit on a 72 with a 4/6 drop.
'72 chevy shortbox---454cid/th400 |
04-20-2007, 07:51 PM | #16 | |
laying low
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
04-20-2007, 07:55 PM | #17 | |
laying low
04-20-2007, 07:58 PM | #18 |
How much backspacing are you guys using. I am looking in too getting wide wheels also. But was unsure about backspacing ? I'm a thief cuz I just stole this thread. LOL
04-20-2007, 09:26 PM | #19 | |
Shawn
04-20-2007, 09:54 PM | #20 |
laying low
I'm sorry. I read fast and had you driving a Burb too. I have never heard if the 73 up front ends were any wider from spindle to spindle than the 72 back. I have an 82 front under my 69. Wheels line up in the fenderwells just like originals. I'd say if the 73 up are wider it is not much if any.
$1700 for steel wheels and whitewalls? What size tires are these? Even if you were buying the wheels, trim rings, caps & lug nuts I would think you'd be lookin at less than $800. $900 for the tires? Did I miss something else?
04-20-2007, 10:10 PM | #21 |
Yes, The tires were 200.00 each. The wheels were 60 each, trim rings 30 each (seems way high) and the caps were 20 each. lug nuts, tax, shipping and road hazard ( since the tires were so darn expensive, and this is a driver).That doesn't even include powdercoating them. Some how it all ended up adding up quick. His cost on the tires alone was 185.00, so he isn't making much on those at all. I'm trying to be cheaper, but I really like the vette rallys and the 285 70 r15 or 255 60 r15 wide whites. I am still in sticker shock!
Shawn
04-20-2007, 10:25 PM | #22 |
BODY SHOP SUPPLIES INC.
I was wondering about the track width also, my 72 blazer has a newer front end under it (rubber bushings) my front wheels stick out quite abit more, like I bought 1.5" wheel adapter/spacers & that isn't quite enough, it is still a tad wider in front??? Are you dead set on the whites?? You can buy BFGs way cheaper than that.
04-21-2007, 11:38 AM | #23 |
If rcheesem is on here and reads this could you tell me if the fronts stick out past the fenders or show some pics so I can get an idea of what it'll look like.THANKS.
08-25-2007, 12:55 PM | #24 | |
Grand PooBaa Member
08-25-2007, 01:29 PM | #25 |
Hey Jorgensensc,
Now that you've gone to the store to check on Discount tire prices check their site on line. A friend at work saved a ton buying his tires on line. Had them mounted at the local tire shop! Smitty
Smitty '71 Short Fleetside Spring Valley, Ca. |
