04-20-2007, 11:07 AM | #1 |
Air Tank Question
What size air tanks are you guys running? Also do you have some pictures where you mounted them. I am putting them on a 71 swb
Thanks for the input. |
04-20-2007, 11:30 AM | #2 |
Re: Air Tank Question
I run two 3-gallon tanks they are mounted in front of the rear wheel under the bed.
04-20-2007, 02:43 PM | #3 |
Depending on the compressor, it is recommended to run no more than 5 gallons per compressor. Most are happy with 2 compressors and 2-3 gallon tanks.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
04-20-2007, 03:26 PM | #4 |
I run (2) three gallon tanks and one compressor. They can be seen above my gas tank. I went for the stealth look. When the bed is on they won't be seen.
04-21-2007, 01:52 AM | #5 |
2 comps and 2 (3gals) tanks, mount in the inside bed of my stepside truck.
04-22-2007, 04:49 PM | #6 |
Too many projects
1 compressor, 3 gallons
Going to an engine driven compressor and 5 gallons soon...
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
04-23-2007, 12:40 AM | #7 |
Am I the only one that thinks this frame looks way too thin about the axle? Not trying to hate, just thinking about safety.
04-23-2007, 01:29 AM | #8 | |
Too many projects
More info would help us out.
04-23-2007, 08:15 AM | #9 | |
No harm. Marc. |
04-23-2007, 08:31 AM | #10 | |
This is a modified G-body frame (Monte Carlo, Cutlass, Grand National). The frame was modified when I bought the truck but it used a conventional coils spring suspension. the rear section was added by the pervious owner to hold the gas tank and support the rear section of the bed. I did cut te notch but I reinforced the top and side with 1/8" plate. There is actually more metal round the area in question then most frames becuse of the kick up. The time to fix it would be now if people really think that it will be a problem. Feedback welcome. Marc |
