upgraded radiator
I will be pulling my engine in the near future for a performance built 250 and would like to replace my radiator while I am at it. My current radiator seems to be "light duty" to say the best, the truck always seems to run a little hotter than I would like, who makes a good aftermarket radiator for our trucks, or is there something off the shelf that will swap over easily?
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's ![]() 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
Re: upgraded radiator
a four core will swap right in with a few mods and some upper four core support brackets
![]() Join Date: Nov 2001
A stock 3-row (modine part# 366) will work perfectly, no mod's.
If your current radiator heats up at intersections, but NOT at highway speeds... then that's an air flow issue, not a radiator issue... use a good fan and fan shroud... Now true, a larger (4-row) radiator will sometimes cure an airflow issue, but the correct fix is, correct the airflow.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 04-22-2007 at 12:10 AM. |
