Old 04-20-2007, 03:57 PM   #1
shelby987
shelby987's Avatar
NP205, no 4lo
My 70 K20 will not go into and stay in 4lo......if I force the shifter forward, and hold it there as I let out the clutch and creep really slow, it will move, but as soon as I let go of the handle, it springs out of 4lo and gives me a grinding noise as the truck comes to a stop......am I looking at a rebuild or an adjustment to the linkage?
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 04-20-2007, 04:53 PM   #2
Blazer1970
Blazer1970's Avatar
Re: NP205, no 4lo
There is probably something jammed in between the shift rails that is keeping them from going all the way back. 4 lo is both rails pushed all the way back into the case. Get under there and look. A good coating of hard mud will cause what you are seeing.
Blazer1970 is offline   Reply With Quote
Old 04-20-2007, 06:00 PM   #3
Burt4x4
Burt4x4's Avatar
Re: NP205, no 4lo
One thig is extra slop in the linkage can doit too. I used a big washer and ground one side so it would fit to fill the gap from the ware-n-tear over the years to remove the slop.
Good Luck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 04-21-2007, 10:44 AM   #4
Re: NP205, no 4lo
I`m thinking it`s in the linkage,too.
Old 04-23-2007, 11:17 AM   #5
shelby987
shelby987's Avatar
Re: NP205, no 4lo
is this transfer case truely bullet-proof enough that you are all confident that I am just looking at a simple linkage problem, or is a potential rebuild in my future worst case scenario?
To look at my truck, I really don't think it spent all that much time doing any real tough 4x4 use (no lift, small tires, stock 250 when i bought it).
Old 04-23-2007, 11:34 AM   #6
1969K10
1969K10's Avatar
Re: NP205, no 4lo
when I got mine (different X-fer), the PO had put it back together and "forgot" to tighten everything up. You'd be amazed at how much that helped the shifting...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 04-23-2007, 10:34 PM   #7
Re: NP205, no 4lo
Yes,bulletproof.Trans guys say they only see them for leaking,like the 4spd trannies.
Old 04-23-2007, 11:45 PM   #8
eedgell
It's the air up here
eedgell's Avatar
Smile Re: NP205, no 4lo
yes, bullet proof, and every one that I have been around is a bit hard to go into 4L. linkage, wear and mud are usually the culprit. Rarely the case its self. I have one in a 79 3/4 ton, 400,000 mi plus and still strong!
eedgell
eedgell is offline   Reply With Quote
Old 04-23-2007, 11:58 PM   #9
snj8198
snj8198's Avatar
Re: NP205, no 4lo
eedgell
I agree.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 04-24-2007, 12:58 AM   #10
Wreckless_71
Wreckless_71's Avatar
Re: NP205, no 4lo
Even If it is a rebuild it isn't hard to do. Factory rebuild and overhaul manuals help a lot!
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 04-24-2007, 03:38 AM   #11
1969 GMC
1969 GMC's Avatar
Re: NP205, no 4lo
I don't know about bullet proof (has anyone ever tested that statment? )
I've seen them go poof before. But it took over 500 hp, and some 44" boggers, on some not-so-friendly sandstone.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-24-2007, 08:25 AM   #12
shelby987
shelby987's Avatar
Re: NP205, no 4lo
great to hear, I will check the linkage next time I get a chance.....big load off my mind!
