Old 04-20-2007, 04:28 PM   #1
SkylineNXS
SkylineNXS's Avatar
First time engine test
When i first bought my 66, it had sat fro a few years in a storage unit, nad now, after a few / 6 months of sittin in my garage, im finnally ready (i think) to try and start it up. I was wondering if u guys could tell me anything else i would need to do before i try and start it. What follows is a list of what ive done. Thanks guys.....
Filled with Collant
New Oil and Filter
New Spark Plugs
New points and condensor
New engine wiring harness
"new" battery
Fuel line is ran to in cab tank
Anything else i chould do? Thanks again.....
Brad
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 04-20-2007, 05:14 PM   #2
Jonboy
Slots go on anything!
Re: First time engine test
Since it has been sitting that long, I would pull the distributor and prime the oil pump. That way there will be oil in the top end when you start it up.
Old 04-20-2007, 06:39 PM   #3
SkylineNXS
SkylineNXS's Avatar
ok cool, thanks
Brad
Old 04-22-2007, 10:57 PM   #4
evilweevil1
Put the bigest filter you can find on the fuel line to catch the mice etc. when it comes out of that old gas tank!!! sitting that long it's gonna be "NASTY"
evilweevil1 is offline   Reply With Quote
Old 04-23-2007, 10:46 PM   #5
baddawg65
baddawg65's Avatar
A carb kit may not hurt.
baddawg65 is offline   Reply With Quote
Old 04-24-2007, 03:55 AM   #6
rwgregory
Just to be safe, pull the plugs and squirt some Marvel Mystery Oil into each sparkplug hole and let it sit and soak in for a day or two. When you are ready to turn the engine over do it by HAND!! Use a large breaker bar on the harmonic balancer bolt and see if the engine will turn over. If it does then your rings have not fused themselves to the cylinder walls. If the engine is loose, leave the plugs out and spin it over with the starter for about 30 seconds or so. This should spit out all of the Marvel Mystery Oil and get everything used to moving again. Reinstall plugs and wires, pour some fresh gas down the carb throat,(have a fire ext. handy) and see if she will light off. Good luck. RWG
rwgregory
67 GMC 2500 ,2w/d wide box
305 V-6, 4-speed
rwgregory is offline   Reply With Quote
Old 04-24-2007, 06:58 PM   #7
SkylineNXS
SkylineNXS's Avatar
The nice hting is that we got lucky and when we did the first turning a while back, it went fine, wdid the breaker bar thing then the started for a while. It worked nice. I also did bebuild the carb, and it seems ok, lol. Still havent tested it with gas, but sometime. Thanks for the input guys....
Brad
Old 04-24-2007, 09:46 PM   #8
hewlett2002000
hewlett2002000's Avatar
my truck set for 2 or 3 years before i got it. i just changed the plugs and wires, oil, and cleaned the carb up, and it fired right up. engine had less than 5000 miles on it when it was parked though.
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 04-24-2007, 10:18 PM   #9
Swerve-Driver
Ditto on having the fire extinguisher ready. I had flames lapping up the fire wall during the first startup of a new engine (flooded, gas dripping out headers caught fire) and it saved my skin.
It sounds like all the posts have pretty much covered all the possibilities.
Might also visually check the spark at at least 1 cylinder with a spare plug just to ensure its intensity. Sounds like a lot of work took place around the plugs/points/battery/wire harness area- just to be sure there is spark before cranking for a long period.
At any rate best of luck on the start-up. I personally prefer to wait until about 2:30am Sunday morning to perform this kind of work and have had excellent results doing it through open headers (just to keep the neighbors honest)! I believe they are secretly envious, but I could be wrong.
Will the '66 see the road this summer?
Best-
S-D
Swerve-Driver is offline   Reply With Quote
