Old 04-20-2007, 06:18 PM   #1
62 short step
62 short step's Avatar
alignment
What is the best driveway method until I can get to an alignment shop. Its pulling to the right pretty good. Its my 61 4x4. Thanks, Jeremy.
62 short step is offline   Reply With Quote
Old 04-21-2007, 10:01 AM   #2
Eichorst69
Re: alignment
Make sure the right front brake shoes are not too tight against the drums, check the king pin bearings and measure the toe. Measure the toe by first making sure the front tires are facing straight forward, then measure across the front of the tires from a point in the tread. Do the same on the rear of the front tires from that same point in the tread. Adjust the front tie rod until you get the same measurements.
Rob
Eichorst69 is offline   Reply With Quote
Old 04-21-2007, 10:09 AM   #3
62 short step
Re: alignment
You know yesterday when I had the tires off, the right front drum was hard to turn. Well looks like I have something to look at today. Thanks for the info!! Jeremy.
Old 04-23-2007, 11:19 AM   #4
1969K10
1969K10's Avatar
Re: alignment
You'll actually want the front measurement to be about 1/16 - 1/8" less than the rear measurement. We aligned my buddies van like that, and he never did take it in to the shop, and the tires lasted a long time.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 04-23-2007, 11:36 AM   #5
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: alignment
Do a quarter inch toe in (1/4 narrower in the front). Don't worry about caster/camber in the driveway, can't do anything about that there. Measure from abou the same point on the inside of the tires as high as you can against the frame.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 04-23-2007, 02:34 PM   #6
62 short step
Re: alignment
The weight of the truck has to be on the ground right? Not up in the air on jack stands?
Old 04-24-2007, 09:03 AM   #7
Bus Ted Knuckle
Son of a gun
Re: alignment
Jack it up to set the toe in. If you measure while on the ground, the tires may be distorted after you turn them in/out and give you a false measurement.
BEATERS ARE NEATER
Old 04-24-2007, 11:09 AM   #8
62 short step
Re: alignment
Thanks man!!
Old 04-24-2007, 07:51 PM   #9
LONGHAIR
Re: alignment
With a straight axle four wheel drive the only thing that you should have to adjust is the toe. The amount of toe-in is largely determined by tire diameter. With really big tires you need a little more toe-in if you are measuring at the tread, mainly due to the fact that the diameter itself causes the same adjustment to measure a greater distance because you are measuring further from the center.
The caster and camber are built into the axle and "theoretically" can't change.
Camber can really only change by wear or damage. (If the ball-joints are very warn or the axle housing itself is bent)
Caster really can't change unless someone physically alters something. Shims under lift kit springs, extremely long shackles, etc.
Assuming that your tie-rod ends are sound there really is no reason for the toe to need adjustment either. The only time you would need to is when you are actually replacing any of the above mentioned "wear items". (Tie rod ends, ball-joints)
LONGHAIR is offline   Reply With Quote
Old 04-24-2007, 11:49 PM   #10
Bus Ted Knuckle
Son of a gun
Re: alignment
Um, well...kinda, This is not a perfect world. We have pot holes and rough trails that can bend things, and normal wear on parts that are not even worn out yet can change toe in. For example: A little bit of change at the tie-rod end is magnified at the leading edge of the tire by distance from the source of the variation. No two set of tires will align the same either due to manufacturing differences and construction variations.
It's always a good idea to keep an eye on your tires for wear, and to check your alignment a couple of times a year.
BEATERS ARE NEATER
Last edited by Bus Ted Knuckle; 04-25-2007 at 12:30 AM. Reason: fat fingers and misspelled words
Old 04-25-2007, 07:46 PM   #11
LONGHAIR
Re: alignment
Not so...If something is bent, it should be replaced, not adjusted to compensate for the bend. If ball-joints are warn enough to "move" they are warn out. And finally, alignment is not based on tires at all. It is really based on the relationship of the bolt flange area of the hub to the ground and the arc in which it moves. It is just easier to measure from the tire, which you really shouldn't do. The tread blocks of large off-road tires can vary quite a bit. The most accurate way to measure toe-in from the tread is to make a mark on one tread block on each side at the front, take your measurement. Then spin the tires so that the mark is in the back when taking the measurement there. This takes any tread variation out of the equation.
They even make tapered shims that go behind the spindle to compensate for camber issues...........but this should not be done. Camber can only change if something is bent (axle housing, spindle). It should be fixed properly, not masked. Steering and braking are serious saftey issues.
Old 04-25-2007, 08:10 PM   #12
Bus Ted Knuckle
Son of a gun
Re: alignment
No body said you shouldn't replace worn or bent parts , man.
Alignment absoloutly has MUCH to do with tires, (that is why you should have your truck aligned each time you get new tires)
Ball joints DO move (that is why they were invented to begin with).
The most accurate way to measure alignment doesn't have squat to do with a measuring tape.
Oh well,
I'll let you win
BEATERS ARE NEATER
Old 04-27-2007, 08:08 PM   #13
LONGHAIR
Re: alignment
Yes you did.
Alignment absolutely has MUCH to do with tires, (that is why you should have your truck aligned each time you get new tires)
Alignment has nothing to do with tires as far as measurement goes. Putting a different tire on your truck doesn't affect the alignment at all.
Ball-joints "rotate" ........they should not move in any other plane. They really don't need to be "balls" at all. They could very well be a straight shaft like the old "kingpins". In fact Dana 60 axles (and closed knuckle 44s in early jeeps among others) use a tapered roller bearing at the bottom and a similarly shaped bronze bushing on top. Any movement of ball-joints requires replacement.
The only thing we are measuring here is toe. None of the others need "measuring" on a straight axle 4x4.
Old 04-27-2007, 08:42 PM   #14
62 short step
Re: alignment
Any way, I did the toe in with a tape. It was good, so I didnt have to move it. But it still pulls to the right. I guess I'll wait to bring it to the alignment shop after I change the axle to a open knuckle . Thanks for all the help!! Jeremy
Old 04-28-2007, 04:42 PM   #15
LONGHAIR
Re: alignment
All in all, your problem is still most likely in the brakes. Not necessarily just the fronts either, a dragging drum anywhere can cause drifting/pulling.
Since you say that it pulls to the right, it could also be in the wheel bearings. If the adjustment nut/washer pack is not properly installed, the right side can tighten itself.
Jack the truck up and try to turn and or wiggle everything....wheel, tie-rods, drag-link,etc. If you find the right wheel stiffer than the left....more investigation is going to be needed.
This of course assumes that you have the same size tires on each side of the front wheels and that the inflation is at least close to equal.
