Old 04-20-2007, 06:20 PM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
How many cross sills for a fleetside wood floor?
There is the obvious one in the far rear of the bed, but how many other cross sills are required for a short fleet wood floor? And since there are two different heigths, how many of each of those? Anyone have a pic of their floor showing all of the cross sills?
TIA!
Bob
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-20-2007, 07:26 PM   #2
72chevy327
Re: How many cross sills for a fleetside wood floor?
I am pretty sure its 3 of the long ones (2 fount and 1 rear + rear sill) and 1 short one, pleas correct me if i am wrong.
72chevy327 is offline   Reply With Quote
Old 04-20-2007, 07:36 PM   #3
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Talking Re: How many cross sills for a fleetside wood floor?
starting at the rear you have the main cross brace , then you have a large cross sill then the shorter cross sill the two more large ones , a total of 4 sill's 3 large 1 small and the main rear crossmember , from memory but I think thats correct
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 04-21-2007, 01:32 AM   #4
glock35ipsc
Cool, thanks guys!
Bob
Old 04-21-2007, 03:06 AM   #5
stevess11
You need four. The big one in the rear and the three that support the wood. There is a opional reinforcing strip that is recomended if your going to haul heavy items.
stevess11 is offline   Reply With Quote
Old 04-21-2007, 08:42 AM   #6
RustyParts
RustyParts's Avatar
If your going from steel to wood isn't the front header also required? Aren't the sills also turned upside down?
If youv'e already got a wood bed you already know this so don't pay any attention to me.LOL
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 04-21-2007, 08:50 AM   #7
Yes,Yes,and I`m not.
Old 04-21-2007, 08:51 AM   #8
RustyParts
RustyParts's Avatar
Thank you, I hate makin' an arse of myself.
Old 04-21-2007, 09:06 AM   #9
msgross
msgross's Avatar
I have already cut my rear sill out in this pic (large one) My reinforcement strip in front of wheel wells is rotted and the PO added that large steel plate over the axle for extra reinforcement...
1,2,3 same cross sill bolt to frame
RS - reinforcement strip -long and doesn't bolt to frame
rear main cross sill - holds back of bed and wiring harnass
I called MAR-K because their examples are a little confusing. I think that you could add the short reinforcement strip just behind the wheel wells? Since mine has a 1/4" piece of steel added then I only purchased the long stip from them. The front panel is different than a steel floor as well.
Hope this works...
Mike
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-21-2007, 10:45 AM   #10
glock35ipsc
RustyParts, I'll just ignore ya then!
Thanks for that picture Mike! It's an all new bed, meant for a wood floor. I've never seen a good pic or had a good description of where they go. Since I doubt I will ever haul anything heavier than a cooler, so I don't guess I will need all the extra strips. I will need to notch the rear sill (not the main one) to clear the Blazer tank.
Thanks agagin guys!
Bob
Old 04-21-2007, 03:36 PM   #11
powell72
powell72's Avatar
BTW Bob, along as we're talking beds, the bed on the wife's truck is 3/4'' from the cab now that it's secured. I forgot you asked awhile back.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 04-21-2007, 05:48 PM   #12
msgross
msgross's Avatar
I have to notch #3 as well due to a Blazer tank install. Hope that it helped, I can search for more if need be. I would guess that mine was all original since nothing was salvageable!
Luckily I found a complete set of all 4 sills and strips at Carlisle last year for $120.
The Garage:
Old 04-21-2007, 08:28 PM   #13
This is good info.The almighty LMC reference bible just lists A/R(as required).Real helpful.I guess your s`posed to ask their operators...yeah right.They must want you to over order to move move volumn or under order so they can make more off shipping.
Old 04-23-2007, 10:05 AM   #14
glock35ipsc
Thanks Chris!
OK, sounds like I am good to go then. I think I will look into using one of the thinner ones over the gas tank, then make some mounts to fill the gap between the thinner sill and the frame. I have the thinner one over the gas tank right now, tied together between the back side of the wheel tubs, and it clears the tank.
Bob
Old 04-23-2007, 10:48 AM   #15
msgross
msgross's Avatar
good idea on the thinner one, I might look into that...
The Garage:
Old 04-23-2007, 05:01 PM   #16
GMCPaul
Short wheelbase trucks need the following to replace all original stock pieces
3- Cross Sills
1- 49.5" reinforcement Strip 1"high
1- 72" reinforcement Strip 1"high
1- Rear Cross Sill
Long wheelbase trucks need the following to replace all original stock pieces
5- Cross Sills
1- Rear Cross Sill
GMCPaul
GMCPaul is offline   Reply With Quote
Old 04-23-2007, 05:21 PM   #17
glock35ipsc
Thanks, GMCPaul. Do you know the location of the two reinforcing strips?
Bob
Old 04-23-2007, 06:25 PM   #18
GMCPaul
72" at leading edge of wheel tubs and the 49.5"is about 1/2way maybe 2/3rds the way from back of rear wheel tubs.
GMCPauls
Old 04-23-2007, 07:34 PM   #19
glock35ipsc
Thank you very much!
Bob
Old 04-23-2007, 11:19 PM   #20
msgross
msgross's Avatar
looks like mine was missing the short strip but it had the steel plate installed by the PO to help...
The Garage:
