Old 04-20-2007, 11:37 PM   #1
Rc 415
Flat Black, & Chrome!
Rc 415's Avatar
Are these 3" drop spindles for 73-87?
Are these 3" drop spindles?
1983 Chevy C10 Stepside Sold
http://s69.photobucket.com/albums/i76/rc_415/
Rc 415 is offline   Reply With Quote
Old 04-21-2007, 12:12 AM   #2
Rc 415
Rc 415's Avatar
Re: Are these the correct spindles for 73-87?
Old 04-21-2007, 12:24 AM   #3
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
dont know. what happened to yours? had a set but through them away
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 04-21-2007, 12:25 AM   #4
Rc 415
Rc 415's Avatar
You threw away a 200 dollar set of drop spindles???/
Old 04-21-2007, 12:27 AM   #5
Srubydo1986
The Crazy Machanic
my bad didnt catch the 3 in drop in it thought they were stock.
newest additions
Old 04-21-2007, 12:34 AM   #6
Rc 415
Rc 415's Avatar
Oh ok lol
Old 04-21-2007, 02:11 AM   #7
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
I'm not sure it they're 2 1/2" or 3" drop spindles. Maybe, someone running Bell Tech drop spindles can verify the part number. From what I can tell, I don't think that they're for 73-87 trucks. They may be for the 71-72 models.
Maybe you can check with Bell Tech (1.888.712.8811) if all else fails.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 04-21-2007, 01:03 PM   #8
kevinr1970
Re: Are these 3" drop spindles for 73-87?
It looks like the number cast in the spindle is 31200. Looking for that number in the BellTech PDF catalog I come up with 3120 - 71-72 1/2 Ton Chevy C10 3" drop.
http://www.belltechcorp.com/products/gm/fullsize.htm
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 04-21-2007, 02:05 PM   #9
Rc 415
Rc 415's Avatar
Guys, I believe these are not the conventional Belltech drop spindles, because they look nothing like eachother, but these do look exactly like the ones GMCPauls sells.
Old 04-22-2007, 04:43 AM   #10
kevinr1970
I am not sure what you mean by that exactly? Are you saying Bell makes a spindle for GMCPauls?
It is clearly cast with the Bell logo on it.
2000 Tahoe Limited
Old 04-22-2007, 12:33 PM   #11
Rc 415
Rc 415's Avatar
I have no idea how it works, mabye gmc pauls sells old stock, but all you have to do is look and you will see, they are identical.
Old 04-22-2007, 12:55 PM   #12
bigblock73
yeller
bigblock73's Avatar
Bell tech only makes 3" drop spindles for our trucks...so if you are sure these are for a 73-87, then they are 3" units. Remember, they make two different 3" spindles, one for 1" rotors, the other for 1.25" rotors.
bigblock73 is offline   Reply With Quote
Old 04-22-2007, 01:25 PM   #13
Rc 415
Rc 415's Avatar
yeah these are 1.25 rotors.
Old 04-22-2007, 03:17 PM   #14
boxrodz
boxrodz's Avatar
Rc 415 -
I don't think that I'd go by the picture. It looks as though they use that image as a picture for some of their other non-73/87 drop spindles. BTW, I believe the 71-72 trucks used only the 1 1/4" rotors. I still tend to think that they're non-73/87 drop spindles. But, I'm not sure.
boxRODz
Old 04-22-2007, 03:20 PM   #15
boxrodz
boxrodz's Avatar
Jeff -
I thought that Bell Tech's first offerings for drop spindles for these trucks were only 2 1/2". I've thought that for the longest time. But, it seems that make only 3" drop spindles as you mentioned. Uhmmmm......
boxRODz
Old 04-22-2007, 03:56 PM   #16
bigblock73
yeller
bigblock73's Avatar
Marcus, Western Chassis makes 2.5" spindles, perhaps you were thinking of them?
Old 04-22-2007, 10:25 PM   #17
wildmanaaron
I have a set of the same part number that I boiught at a swap meet. Call Belltech and give them the dimensions of them. I called about mine and they said Yes that they are for 73-87 with 1.25" brakes. The part # on mine was 31200 as well.
wildmanaaron is offline   Reply With Quote
