Fuse for radio
I am installing a factory AM radio in my 69 GMC out of my 70 GMC parts truck.
What type of fuse goes in the fuse box for the radio? I am thinking that my power lead from the radio plugs right onto the front of the fuse box.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
Re: Fuse for radio
Radio feeds off the heat fuse (to check just flip fuse up on one side to see if radio goes off.)
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Re: Fuse for radio
i have an after market deck in mine and i just found a good power source and pluged into it, i think it might be that plug to
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Who's got steelies?
![]() Join Date: Feb 2006
Re: Fuse for radio
The fuse labels in that photo are a little off, if you have a non-ac truck. The radio fuse is the one labeled "heat", and should be 3 amps. If you have AC, things are a little different, look in the factory service manual for your year, it tells you exactly what is different with a factory set up.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
Re: Fuse for radio
Well that helps, my heater motor wasn't working and the fuse was good. But when I changed the AC fuse the heater motor was getting power again.
