Torsion Bar Questions
Hello-
I have a 62 chevy with the torsion bar set up. My questions are: How can you adjust the height? How easy is switching to coil springs if height adjustment is a pain? Thank you, Matt
1962 Chevy Fleetside
283/TH350 |
Re: Torsion Bar Questions
yes you can adjust them un do the maim bolt at the end and that will lower the suspention if you need more lowering height you can pull the bar out and rotate it then try again. make sure you suppot the front befor pulling the bar out and mark the bar in the original position then do the other side.
vinnie 1960 chevy c10 frame with a 1966 cab 2002 dodge intrepid r/t 2004 chevy 2500 4 door short bed |
![]() Join Date: Oct 2006
Easy to addjust: Spray some pb blaster or wd 40 on the before to adjust them There is a screw/nut assembly at the end of thr torrsion bars, by the tranny. jack up the truck, and use jack stands. then just turn them counter clock wise .Try to do the same anount on each side . Dont back them off too much . Thats it. here is a before and after of my 60
Great! That is what I was thinking, but was nervous to start unscrewing things and have the bar flip out or something crazy happened.
Thanks guys!!! -Matt
283/TH350 |
![]() Join Date: Aug 2005
This was with the torsion bar adjustment and lowering blocks in the rear.
Hollister, CA.
![]() Join Date: Sep 2006
NO, NO, NO...the best way is take a TORCH...and heat the middle of the torsion bar and what the truck come down !!!!
Just kidding...you didn't think I was serious...did you ?? John
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 04-21-2007 at 01:28 PM. |
Here's a before and after of my 60
'66 C10 Longbed Stepside, 350, 4-speed |
John-
Bahahahaha!!! I have heard of some crazy stuff, so you actualy had me thinking you might have tried that! Wow... imagine walking up and seein a guy putting the heat on like that. Yikes! Ratrd60apache- Thanks for the picks! I don't want the slammed look, and yours sits nice, so I think I wil be able to get away with just adjustment. Sweet. Thanks All -Matt
283/TH350 |
