Old 04-21-2007, 09:18 AM   #1
68 P.O.S.
Ground straps
I have 1 ground strap that goes from the batt to the engine and that's it. I've read that you should have 3, so where do the original ground straps connect to or where is th best place for them?
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 04-21-2007, 09:34 AM   #2
RustyParts
RustyParts's Avatar
Re: Ground straps
On mine there are two straps mounted between the firewall and the rear bolt on each valve cover and I'm not sure but I think the other is mounted under the cab from the front cab support to the frame.
Doesn't really matter as long as they're between the frame and bodymetal, the cab and bed cushions kinda act like insulators so you need the straps to provide a good ground from the frame to body.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 04-21-2007, 10:10 AM   #3
Hart_Rod
Hart_Rod's Avatar
Re: Ground straps
What RR said. This is where I usually start:
Body (Cab and Bed) to Frame
Frame to Motor
Motor to body
Scrape paint to bare metal to get as good of contact as you can.
Hart_Rod is offline   Reply With Quote
Old 04-21-2007, 11:59 AM   #4
jamis
F.A.S.T. president
jamis's Avatar
Re: Ground straps
Batt to motor (4 gauge min.)
Frame to cab (strap or 10 gauge min)
Motor to frame (strap or 10 gauge min) I like this better then motor to cab, cab gets its ground from the frame to cab
Optional
Batt to rad support ( 10 gauge, I like to run this to help with grounding of lights, horns, electric fans, etc)
The bed does not have any rubber isolators just make sure you have clean metal between frame and bed or add a strap if you have ground issues with tail lights.
Clean paint from surface for ground terminals, use a star washer between terminal and surface (frame and body) then brush over with some liquid electrical tape to keep from corroding.
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 04-21-2007, 05:13 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Ground straps
there's supposed to be straps to the bed from the frame too... and if you have a wooden floor, they are pretty important.
