Old 04-21-2007, 09:35 AM   #1
Nima
Blue 67
compression testing
When you do compression test, do you remove all the spark plugs at once or one at time when you are testing each cylinder? Does the cylinder has to be on TDC? I got kind of confused about compression test and leak down test. would somebod explain this to me.
Thanks a lot.
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 04-21-2007, 10:48 AM   #2
As2rd
As2rd's Avatar
Re: compression testing
Im pretty sure you just have to take one spark plug out, disconnect the ignition system and screw the hose onto the spark plug hole with the gauge. then have someone turn the key at WOT. let them hold the key over until the gauge stops increasing. Ill tell you about a good or bad compression test if you need me to. But thats how you set it up, I think. Make sure you let the starter cool down and to make sure there is no gas in your testing hose, or it will give you a bad reading.---Andy
1972 Chevy Truck
350ci/th350 Auto.
Daily Driver
As2rd is offline   Reply With Quote
Old 04-21-2007, 11:44 AM   #3
cdowns
cdowns's Avatar
i take all out its easier to spin the motor that way
Old 04-21-2007, 12:18 PM   #4
gnarkill
gnarkill's Avatar
all spark plugs out, hold throttle wide open, spin engine for about 4-5 secs.
gnarkill is offline   Reply With Quote
Old 04-21-2007, 04:04 PM   #5
Nima
Blue 67
If I take all the spark plugs out, do I need to disconnect the ignition still?
Old 04-21-2007, 04:38 PM   #6
neonlarry
neonlarry's Avatar
No, just stay away from the wires with your hands though.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 04-21-2007, 05:02 PM   #7
AR15DEFENSE
Resident Absorber
AR15DEFENSE's Avatar
you want to do it while the engine is warm also.. ex: engine at op temp, then pull all plugs and comp test. after testing all cylinders dry, test each one again after a small squirt of oil. If compression gets significantly better after the squirt of oil, that indicates bad rings or scored cylinder walls.
The best offense is a better DEFENSE!
AR15DEFENSE is offline   Reply With Quote
