Old 04-21-2007, 12:44 PM   #1
72step
72step's Avatar
Cargo Lamp Mounting Question
I need to reinstall the cargo lamp on my truck, however, I've been putting it off because the cab, has these big holes with some sort of nut kinda sealed into the bigger hole, and on one side the nut is gone. What is the typical way these lights go on? Not sure if it was messed with by a previous owner, or if that's the way they go in? I might just drill a bigger hole into the cargo lamp housing and use a regular bolt and nut, but I hate to do that. Any ideas? Thanks.......
72step is offline   Reply With Quote
Old 04-21-2007, 03:27 PM   #2
powell72
powell72's Avatar
Re: Cargo Lamp Mounting Question
Just use one of those rubber plugs with the threaded inserts from the hardware store in there. If you buy a repop cargo lamp that's all they send you.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
