Old 04-21-2007, 04:41 PM   #1
harleyx2
lowering 1968 truck and adding disc brakes
what is the cheapest way to lower my 68 chevy truck while also adding 5 lug disc brakes? i have power drum right now so will i need to change the booster also.
harleyx2 is offline   Reply With Quote
Old 04-21-2007, 09:23 PM   #2
harleyx2
Re: lowering 1968 truck and adding disc brakes
anyone? if i do the 73-87 crossmember swap is the wheel mounting surface to wheel mounting surface measurments the same frome side to side on the 67-72 stuff as the 73-87 stuff? and when you do this swap and go to get the alignment done what year model truck do you tell them to use the specs for? 67-72 or 73-87 specs?
Old 04-21-2007, 10:31 PM   #3
msgross
msgross's Avatar
booster still works but you need to ditch the distrobution block for a propotioning valve. MC might need changed...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-21-2007, 10:34 PM   #4
Ole Blue 68
Ole Blue 68's Avatar
The width should be the same or the difference so minimal that you won't notice it.
Ole Blue 68 is offline   Reply With Quote
Old 04-21-2007, 10:35 PM   #5
Ole Blue 68
Just did the swap, MC definitely needs to be changed.
Old 04-22-2007, 12:06 AM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
I have a 68 in my garage that has hada front crossmember from an 87 Chevy bolted under it and it appears to be very much the same as the original dimensions. I am changing my front to Classic Performance Products tubular A arms and using 3" drop spindles for my lowering.
piecesparts is offline   Reply With Quote
Old 04-22-2007, 12:35 AM   #7
raiders3581
Junior Member
raiders3581's Avatar
just be aware that if you end up going with disc brake drop conversion spindles your front wheels wheel have a wider track of about inch and a half on both sides.
67 short bed fleetside/1997 c1500 exteded cab/ 2004 accord/87 c10silverado 350 od tbi
raiders3581 is offline   Reply With Quote
Old 04-22-2007, 01:56 PM   #8
harleyx2
so if you do the 73-87 swap and go to get a alignment what year model specs dop you tell them to use? 67-72 or 73-87?
Old 04-22-2007, 05:07 PM   #9
piecesparts
What ever year that you chose to use.
