It's the air up here
Frame numbers
Where are the frame numbers located 1967 thru 1972 like the VIN#?
eedgell |
![]() Join Date: Feb 2004
Re: Frame numbers
Passenger Side top of the frame right front frame area
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
Re: Frame numbers
Thanks a bunch! Is that in the cab portion, the front clip portion or the bed portion? Top of frame, side of frame?
eedgell |
BlahBlahBlah
Re: Frame numbers
On top of the frame kinda close to the tire
Re: Frame numbers
That helps alot. Thank you. I will start there
eedgell |
Re: Frame numbers
i believe right by the passenger side engine mount on the top of the frame rial
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4 70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s |
Parts and more parts
Re: Frame numbers
Are you sure it is the passenger side? I found the numbers on the dirver's side under the floor boards, on my 68.
Re: Frame numbers
Is it different for different years 67 to 72?
eedgell |
![]() Join Date: Apr 2005
Re: Frame numbers
My 67 CrewCab has them on the drivers side frame rail.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
its all about the +6 inches
Re: Frame numbers
they are found under the cab, and up front just aft of the steering gear box on top.
Re: Frame numbers
My 68 K-10 has the vin on top of the driver frame rail near tire and under the cab. There are other numbers stamped on the sides of the frame rail but I don't know what they are.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Re: Frame numbers
Here on my 67, there may be others but still covered in mud & rust.
#13 |
Re: Frame numbers
Thanks much to all this helps alot. You guys are great!
eedgell |
