Old 04-22-2007, 01:27 AM   #1
corkscrew
Where is the headlight relay???
I need to check for mine because its probably a bum one. also a part number would be great. thanks for your help as always guys
corkscrew is offline   Reply With Quote
Old 04-22-2007, 01:31 AM   #2
StingRay
StingRay's Avatar
Re: Where is the headlight relay???
No relay on a 67-72. Just the switch and the dimmer switch control it all.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 04-22-2007, 01:32 AM   #3
corkscrew
i have a painless wiring harness by the way
Old 04-22-2007, 01:33 AM   #4
corkscrew
O well then do you have a different explaination for the head lights coming on by the selves while the side markers do not come on at all. I got the new euro lights from LMC...and the headlight harness
Old 04-22-2007, 12:26 PM   #5
corkscrew
bump
Old 04-22-2007, 09:11 PM   #6
FLEET72
FLEET72's Avatar
Are you refering to this?
LMC Euro Headlights and Heavy Duty Harness
Improperly wired? loose connector?
http://67-72chevytrucks.com/vboard/s...9&postcount=19
More info, does this anomaly happen while parked, key off? While driving down a bumpy road?
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 04-22-2007, 09:19 PM   #7
corkscrew
happened for the first time sitting after 2 days the lights just turned on. im pretty sure its a faulty relay since they were submerged in water. yes that is the harness im talking about
