Old 04-22-2007, 04:46 PM   #1
liljon285
That Guy
liljon285's Avatar
Need help with a screw!
I recently got a screw stuck on my engine head(the one that holds the valve cover, the screw broke in half!) and i got this tap thread repair kit, it has a drill bit thats lon and looks like a screw at the end of it, and another that im guesin is to tap, and it also has these little spings or coils that i dunno what to do with. Can any one help me.
See:
These i can use but i dunno how or in what order:
These are the coils which i hvae no idea what to do with:
1978 Chevy Scottdale Stepside, 3rd engine- 350c.i. built with cam and lifters, holley 670cfm carb. and intake,heads shaved .60. Truck is a project, and I am its restorererer!
liljon285 is offline   Reply With Quote
Old 04-22-2007, 04:52 PM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: Need help with a screw!
The little coils are the thread replacements. You need to drill the hole in the head oversized but smaller than the little coils. Then use the tap to cut new threads into the head. The little coils should have an installer tool to screw then into the new threads that you tap, then you can bolt it back together...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 04-22-2007, 04:57 PM   #3
liljon285
That Guy
liljon285's Avatar
I use the black one then right to install the coils, and the coils stay inside?
Old 04-22-2007, 05:13 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Before oyu drill......Is there any part of the screw close to the top of the head. I would see if there is someone that can weld a nut onto it and then you can take it out. The welding would loosen the screw and the nut would become the new head to the screw. That is better than drilling and making a big mess.
piecesparts is offline   Reply With Quote
Old 04-22-2007, 05:14 PM   #5
Jtrux
I'm a poor spectator
Jtrux's Avatar
Exactly, try this first before doing anything else.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 04-22-2007, 05:35 PM   #6
liljon285
That Guy
liljon285's Avatar
No there wasnt, not enough to weld. I already drilled have of the screw down but i need a better drill cuz my bettery one is awesome and its giving up si im guessing i need one of those that connect to an a/c outlet.
Old 04-22-2007, 05:56 PM   #7
SkylineNXS
SkylineNXS's Avatar
Sure u cant just use an easy out, the ones that grab the screw with some reverse facing "blades", its like a drill bit, but reverse, u just hit it into reverse, and it pulls out. Maybe theres not enough screw in order to do it. But those miny coils are helicoil threads, and just like the guys said, drill and tap a larger hole, the the helicoil goes in the new thread, and it itself becomes the new hole, with the correct size thread....
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
