Shifter Upgrade
I have looked everywhere for a shifter upgrade for Dana 20 transfer case on 1970 Blazer and had no luck! I rebuilt the transmission and the transfer case to find no luck in finding either a stock shifter or a performance shifter upgrade. I'm looking for the shifter and the housing case that bolts on the transfer case.
PLEASE HELP! |
I'm a poor spectator
Re: Shifter Upgrade
Keep looking, i'm sure you'll be able to find a twin stick conversion for it somewhere. Dana 20's were used in a lot of different vehicles so someone is bound to have made something or since you said previously that you want to wheel this truck hard, replace the 20 with a NP205.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! Last edited by Jtrux; 04-22-2007 at 05:06 PM. |
Active Member
Re: Shifter Upgrade
http://jbfab.net/Merchant2/merchant...._Code=Shifters
Might try these guys if you are looking for a twin stick. I did not see any listed for a GM application, but they may be able to let you know if any of them will work for it.
Mike T. Oregon 70 GMC Jimmy 4x4 70 Camaro LS1 plans in the works 71 RS/SS Camaro numbers matching 86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear) |
