04-22-2007, 05:13 PM | #1 |
I'm a poor spectator
Big ass clutch pedal spring
I took off that big ole giant clutch pedal spring under the dash to see if it would make for a more comfortable clutch pedal (it does) but got thinking, does this cause anything to mess up. I don't notice anything weird about it but I also got to thinking that there has to be a reason GM put it thataway and i'm sure I would of heard something about it if it was such a great thing to do. Am I wrong, should I put it back?
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
04-22-2007, 05:15 PM | #2 |
its all about the +6 inches
Re: Big ass clutch pedal spring
well, the weight of the pedal could cause a light 'riding the clutch' condition.
I would hook it back up, and see if you could locate a lighter spring maybe. |
04-23-2007, 12:08 PM | #3 |
Longhorns right I took the spring out of my 61 years ago and it slowly whore the clutch out. Just find a lighter spring any spring that will hold the pedal up
04-23-2007, 06:27 PM | #4 |
Big Block
Find a lighter spring. The two spring work together to keep the throwout bearing from riding on the pressure plate and causing wear on the clutch and throwout bearing.
04-29-2007, 12:52 AM | #5 |
Farm supply stores are a good source for springs like the one you will need.
-Scott- |
