04-22-2007, 05:29 PM | #1 |
Frame bolts - Where should you use loctite?
I took the whole frame apart. And put it back togeather without Locktite. Before i go any further I was wondering what places should have it.
The front cross memebr bolts? Lower sway bar bracket bolts? Leaf Spring bolts? Shock bracket bolts? (Switched both sides to get a better angle for the shocks with the drop)
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
04-22-2007, 07:22 PM | #2 |
Re: Frame bolts - Where should you use loctite?
Define----"took the whole frame apart"
such as removed all the x-members? |
04-22-2007, 07:39 PM | #3 |
Only the front crossmember was removed (unbolted)
The front frame mounts for the sway bar was replaced with a bolt in bracket for lowered trucks thus two of four rivits that hold the front crossmembers were removed and replaced by bolts. The rear leaf ubolts and frame mounts were taken apart.
04-22-2007, 08:43 PM | #4 |
I locktite'd everything on my K5.
Mike
Mike Redpath |
04-22-2007, 10:17 PM | #5 |
which color loctite would you recommend
04-22-2007, 10:20 PM | #6 |
Gone Fishing
I would go with the red since it's the strongest. The bolts to the frame most likely will never be unbolted again after this time
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
04-22-2007, 10:53 PM | #7 |
Too many projects
Red on everything, especially if you replaced rivets with bolts.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
04-22-2007, 10:59 PM | #8 |
I wouldnt locktite any of them, i would use lock washers and torque them properly. If you have to use locktite use blue.
Jared
1969 GMC 910 1970 GMC 1500 custom 1972 yamaha 175 "Money is just like trucks you can never have enough" |
04-22-2007, 11:04 PM | #9 |
Actually the best way would be to open up the holes to 7/16'' and use a grade 8 bolt (fine thread) with a grade 8 flat washer on both sides with a type 'C' nut torqued down. RED loctite wouldn't hurt, but not necessary with the C nut.
04-23-2007, 10:33 AM | #10 |
I reamed any holes out that rivets were in to the next size so I had good tight holes. Installed Grade 8 bolts in everything, lock washers, red loctite, and torqued to spec. Then on top of that, I used torque seal, which is a thick paint in a tube that is dobbed on the exposed threads and nut to tell if a nut has moved. I will not go to that extent on the body panels, but I made no compromise on the chassis.
Mike
Mike Redpath |
04-23-2007, 10:58 AM | #11 |
Questionable
I used poly-lock nuts on all of my frame crossmembers AND on my new engine mounts. ECE ships poly-lock nuts and washers with all of their parts, so ... if it's good enough for them .....
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
