Old 04-22-2007, 08:30 PM   #1
corkscrew
Dome Light Question
Ok guys im just wondering how this dome light is wired and how it works. like is the light supposed to come on as soon a door is opened? is there a switch? any dome light help would be great!!
corkscrew is offline   Reply With Quote
Old 04-22-2007, 08:54 PM   #2
Blue85
Oilfield Trash
Blue85's Avatar
Re: Dome Light Question
It plugs into a pigtail coming from the fuse panel, if you have door switches (about half way down between the door hinges) thier harness just plugs into the main dome light harness by the fuse panel. When the door opens, the switch grounds out, and completes the circut.
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 04-22-2007, 09:21 PM   #3
corkscrew
my light is on and never ever shuts off so this is why im asking this
Old 04-22-2007, 09:43 PM   #4
woodrow59
OzarkHillbilly in Atlanta
Do you have door switches ???? Need to figure that out first.
If you don't have door switches, then maybe this will help.
Mine didn't work. Tested voltage. Had voltage. I thought it must be a bad ground. Grounded the dome light to the cab ,,,,HE!! yeah,,,,, I have light. Only problem is it wouldn't shut off unless you took the dang bulb out !!!!!
I had an old light switch and decided to figure out how it worked. Checked the continuity on the connections when the dome light should be on and found out the dome light comes on by being grounded. I fished new wires from the dome light to right underneath the fuse box and spliced them in. Dome light works perfect now.
72 custom/10 LWB
68 Longhorn C20 Custom Camper (sold)
woodrow59 is offline   Reply With Quote
Old 04-22-2007, 09:55 PM   #5
corkscrew
yeah my light will never shut off thats my problem lol
Old 04-22-2007, 10:11 PM   #6
corkscrew
so your saying if i dont ground it it would turn off??
Old 04-22-2007, 10:18 PM   #7
piecesparts
Parts and more parts
piecesparts's Avatar
By chance is your headlight switch knob rotated to the point, the dome light circuit is completed.
piecesparts is offline   Reply With Quote
Old 04-22-2007, 10:32 PM   #8
corkscrew
o maybe it turns on when the knob is turned? thanks man wow i never would have thought of that
Old 04-22-2007, 11:03 PM   #9
72lb4x4
When the headlight switch knob is turned all the way to the left, the dome light comes on. Turning it to the right makes the lights in the guages brighter...
72lb4x4 is offline   Reply With Quote
Old 04-22-2007, 11:12 PM   #10
corkscrew
well that is real good to no lol thank u
Old 04-22-2007, 11:13 PM   #11
Blue85
Oilfield Trash
Blue85's Avatar
Last time i drove my truck at night turning the switch to the right makes the dash lights dimmer, turning to the left makes the dash lights brighter, and all the way left the dome light comes on.
87 Chev 3+3 4x4
Old 04-23-2007, 10:50 AM   #12
piecesparts
YEP, that's how it works. Another life saved.
