cab mounts
What is the distance between the cab floor and the frame with new cab mounts? I'm trying to get a rough fit of the front wrap but I can't order my cab mounts till next month(I've already killed my truck fund for the month) So anyone that has their cab sitting on the new mounts can I talk you into measureing for me or anyone know off the top of their head?
thanks in advance Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
Re: cab mounts
anyone?
![]() Join Date: Apr 2007
Re: cab mounts
I probly have something I could measure up but Ill have to get back hear later on with that info ,test fit is fine dont weld any thing till you have everthing.
Re: cab mounts
sick69;
I measured on my 71 c20 which I put new cab mounts on. Between the frame mount and the surface on the cab floor where the mount go. Front: 35mm, 1,4 inch Rear: 68mm, 2,7 inch Hope it helps.
Mats.. ---------------------------------------------------- 1971 Cheyenne Super Custom Camper 475CBB/TH400/AC 1992 Silverado Sport Truck 1988 Silverado 2500 Ext Longbed 4x4 2001 GMC Sierra SLT 4x4 1990 Chevrolet K3500 1965 Pontiac Grand Prix 1980 Z 28 350/4-speed/AC/T-top 1980 Camaro Coupe V6/3-speed 1979 Buick Century Wagon |
Re: cab mounts
Unfortunatly its a c10 half ton and the c20 3/4 tons are different I believe. I appreceiate the effort though. I should have said what model and tonage I was working on.
So I need to know the distance between the frame and the cab on a 70 c10 half ton with new cab mounts. I'm not sure if it will be different between the rubber mounts and the urythane mounts. I would assume they would be the same. Thanks for the help Frank
Re: cab mounts
I read your post as needing the front mount distance, so I did not measure the rear on a 71 C-10. Anyway on this truck it measures 1 3/8" but I had shimmed the mounts 1/4" to level the cab with the bed. If you take away the shims, then with new poly mounts the distance is 1 1/8".
Attached is a pic of the measurement. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Re: cab mounts
Did you need from the floor to the frame which is really inboard of the mount and the floor rail that runs front to back or from the mount bracket on the frame to the floor support as pictured in the reply above? on my truck also a2500 floor to frame is 1 1/8 the cabs are the same 1/2 and 3/4 this I know and I have to believe they mount on the frame the same way. After all they are Chevys.
Son of a gun
Re: cab mounts
3/4 and 1/2 are the same
Bill BEATERS ARE NEATER |
Re: cab mounts
I was thinking 1/2 and 3/4 were different because of the different parts numbers but ok if they are the same,,,,
I needed the measurement from the frame mount to the cab support as pictured above for the front and the rear. I installed a camaro sub frame in the front many years ago when I started this project and the core support totally misses the frame (by an inch or two) so i'm going to flip the front end. Brackets need to be made to attach the front end to the frame. I can mock up the cab mounts (with the measurements) and get rough brackets built and clean them up after I get my cab mounts. Thanks for the help guys! Frank
